L210--too weak?
/ L210--too weak? #1
Anonymous Poster
Epic Contributor
I have an L210 Kubota (21 HP). The bushhog (Mohawk)is 5' and does fine in thin grass. In the thicker stuff it just bogs down. Do I need to size down, or is there a hog (rotary cutter) that might do better? Blades are fairly sharp, and I'm going pretty slow. The main problem grass is Bahaya (sp)?
/ L210--too weak? #2
Murph,
You're probably a little above the best size for a 21-horsepower tractor - 4' is most common unless you have a very light duty cut to do, then 5' might work to a certain extent. But if you can justify it, sizing down to a 4' cutter would likely make some difference. In your case, you might want to try before you buy, if possible.
/ L210--too weak? #3
Don't know what "Bahaya" grass is, but I agree with Muhammad. When I had a B7100 (16hp), it was a fine little machine, but tall thick grass, fire ant mounds, etc. sometimes bogged it down a bit even with the 4' brush hog. Sounds like you need to downsize the cutter, upsize the tractor, or go very, very slowly./w3tcompact/icons/smile.gif
Bird
/ L210--too weak? #4
<font color=blue>Don't know what "Bahaya" grass is</font color=blue>
I was going to ask the same thing... ???
/ L210--too weak?
Bahaya is a FAST growing TOUGH grass that some people use for hay here in SW Arkansas. But get it in your yard and it's a real pain in the ___. I don't know if the spelling is correct, but it's pronounced that way. Also, it has a long tough stem with seeds growing out the top on little stalks. Anyway, thanks for the replies, also thanks to Mohammed.
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
Two (2) John Deere 5000-Series Tractor Grill Guards (A65640)
Two (2) John Deere...
(INOP) BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) BOMAG...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
Mini Universal Forks (A65640)
Mini Universal...
Stidham 2 Horse Trailer (A65640)
Stidham 2 Horse...
