L210--too weak?
/ L210--too weak? #1
Anonymous Poster
Epic Contributor
I have an L210 Kubota (21 HP). The bushhog (Mohawk)is 5' and does fine in thin grass. In the thicker stuff it just bogs down. Do I need to size down, or is there a hog (rotary cutter) that might do better? Blades are fairly sharp, and I'm going pretty slow. The main problem grass is Bahaya (sp)?
/ L210--too weak? #2
Murph,
You're probably a little above the best size for a 21-horsepower tractor - 4' is most common unless you have a very light duty cut to do, then 5' might work to a certain extent. But if you can justify it, sizing down to a 4' cutter would likely make some difference. In your case, you might want to try before you buy, if possible.
/ L210--too weak? #3
Don't know what "Bahaya" grass is, but I agree with Muhammad. When I had a B7100 (16hp), it was a fine little machine, but tall thick grass, fire ant mounds, etc. sometimes bogged it down a bit even with the 4' brush hog. Sounds like you need to downsize the cutter, upsize the tractor, or go very, very slowly./w3tcompact/icons/smile.gif
Bird
/ L210--too weak? #4
<font color=blue>Don't know what "Bahaya" grass is</font color=blue>
I was going to ask the same thing... ???
/ L210--too weak?
Bahaya is a FAST growing TOUGH grass that some people use for hay here in SW Arkansas. But get it in your yard and it's a real pain in the ___. I don't know if the spelling is correct, but it's pronounced that way. Also, it has a long tough stem with seeds growing out the top on little stalks. Anyway, thanks for the replies, also thanks to Mohammed.
2011 Freightliner B2 School Bus (A61568)
2011 Freightliner...
2000 International 4900 Tandem Truck (A66285)
2000 International...
2012 PROCO 130BBL (A65643)
2012 PROCO 130BBL...
20ft Jumper Cables (A65583)
20ft Jumper Cables...
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
Saltdogg by Buyers, Slide in Spreader Box (A62679)
Saltdogg by...
