Kubota Safety switch
/ Kubota Safety switch #1
jveretto
Buffalo, TX
Kabota L2800
I have a Kubota L2800. Having problems with the safety switch under the shifter I think. I know not to operate without the safety switches in place. However, I would like to make a jumper to confirm it is the switch that is bad before I order said switch. The switch has what looks like two contact points with two wires to each. How do I create a temporary jumper? Thanks in advance!
/ Kubota Safety switch #3
Here is the way the system works.
There are three wires on the switch (black blue orange) that terminate in male pins in the connector.
With the seat only all the way down there should be continuity between the black and orange wire only.
With the seat only up there should be continuity between the black and blue wire only.
You will want to jumper the black and orange wires.
Thanks! I figured out what I was doing!
New/Unused 5ft Quick Attach Mixer (A61166)
New/Unused 5ft...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
2820 (A62131)
2820 (A62131)
2014 Mercedes-Benz C300 Sedan (A61569)
2014 Mercedes-Benz...
2015 Ford F-350 Service Truck (A61568)
2015 Ford F-350...
2017 Chevrolet Colorado Ext. Cab Pickup Truck (A61568)
2017 Chevrolet...
