Kubota M 9540 problem
/ Kubota M 9540 problem #1
buddy in burlington
burlington
Kobota M9540
After working my Kubota M9540 an hour or so, it sounds like something internally is out of balance....like a rod knocking but it is coming from the transmission area. It has a manual shuttle shift transmission and sometimes is hard to shift from forward to reverse and vice versa. Sometimes I have to rock the tractor back and forth with the clutch to get it to shift. Any ideas or suggestions?
/ Kubota M 9540 problem #2
If your tractor has a Lot of hours, the shifter forks could be worn to the point they do not fully engage & disengage...
If it has lower hours, I would suspect a bent fork... KennyV
2003 PETERBILT 379 SLEEPER (A59914)
2003 PETERBILT 379...
28ft. TV Tower (A65640)
28ft. TV Tower...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A61568)
2019 Ford F-350...
2019 Lynco Mini Mover Aircraft Tug Cart (A61567)
2019 Lynco Mini...
