Kubota, first problem
/ Kubota, first problem #21
thanks for the update and glad you found your trouble :thumbsup:
/ Kubota, first problem #22
I know this is an old thread but after searching seems to best fit my issue. Hopefully someone can give a bit of advise. After washing I can not get my l5030HST to start. The dash is showing "HST NUETRAL" in the display. The safety switch(or relay) for the HST on the left by the damper rod. The little rubber boot for the switch(relay) plunger is torn. Neither adjustment nor electrical contact cleaner with a lot of back-and-forth has helped. The safety switch(relay) connection has four contact points in a "x" or box pattern. Question: which of these four contacts do I short to start the tractor and verify the problem point? Thanks!
When I was trying to find the solution to my no start problem the only help I got from my Kubota dealer was a parts print out from the manual. Perhaps your dealer could give you a print out for your machine, and possibly a wiring diagram for the pertinent circuits.
Good luck, Art
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
AGT LRT23 (A64912)
AGT LRT23 (A64912)
2007 FORD F-450 SUPER DUTY BUCKET TRUCK (A67714)
2007 FORD F-450...
2009 CHEVROLET IMPALA (A66091)
2009 CHEVROLET...
NEW HOLLAND 1725 FORD TRACTOR (A65057)
NEW HOLLAND 1725...
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
