Kubota, first problem
/ Kubota, first problem #21
thanks for the update and glad you found your trouble :thumbsup:
/ Kubota, first problem #22
I know this is an old thread but after searching seems to best fit my issue. Hopefully someone can give a bit of advise. After washing I can not get my l5030HST to start. The dash is showing "HST NUETRAL" in the display. The safety switch(or relay) for the HST on the left by the damper rod. The little rubber boot for the switch(relay) plunger is torn. Neither adjustment nor electrical contact cleaner with a lot of back-and-forth has helped. The safety switch(relay) connection has four contact points in a "x" or box pattern. Question: which of these four contacts do I short to start the tractor and verify the problem point? Thanks!
When I was trying to find the solution to my no start problem the only help I got from my Kubota dealer was a parts print out from the manual. Perhaps your dealer could give you a print out for your machine, and possibly a wiring diagram for the pertinent circuits.
Good luck, Art
STAGECOACH  16 FOOT FLATBED TRAILER (A67714)
STAGECOACH 16...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2015 PETERBILT 320 6X4 T/A CNG GARBAGE TRUCK (A66091)
2015 PETERBILT 320...
2009 CHEVROLET SILVERADO 3500 TOW TRUCK (A65057)
2009 CHEVROLET...
2006 Chevrolet Uplander Van (A66738)
2006 Chevrolet...
