Kubota 3710
/ Kubota 3710 #1
Mogrod
Sanford NY
Cub 2550
Does anyone know what the top speed of the Kubota 3710?
/ Kubota 3710 #2
14.4 mph hst
14.3 mph gst
That may vary with tire type.
/ Kubota 3710
The most i can go is 6 or 7 in high gear. It is the HST. Is there a range selector on this machine?
/ Kubota 3710 #4
The L3710 hst will have the treadle pedal and three ranges: High, Medium, Low
Creeper gears were an option, but I am not familiar with their operation.
/ Kubota 3710
Thanks. Not sure why I can't get it to go any faster
/ Kubota 3710 #6
If you have found the range selector and have it in high, maybe make sure the treadle isn't bent? Had a Kioti in the shop with a similar treadle pedal setup and somehow they managed to bend it where it wouldn't have full travel.
/ Kubota 3710 #7
I have an L3710 HST, 14mph is the top speed listed in the owner's manual.
/ Kubota 3710 #8
I don't think I've ever had a tractor that would reach it's rated top speed on anything except the flat paved road or a slight downhill . Certainly not going up even the slightest slope - even on a hard surface road. An uphill that I can barely detect will keep our tractors from using top gear.
/ Kubota 3710 #9
Only tractor I've ever had that had to downshifted going up hill, without a load, was a JD 3020 Propane with a powershift. Either lug it up hill at 1500 rpm in 8th or wound out in 7th.
/ Kubota 3710
It is the HST. I use the H M L. And in H I'm getting 6 or 7 mph. Is there another shifter that has a High Low range?
/ Kubota 3710 #11
I am not familiar with the creeper gear I mentioned earlier. If your machine has the option, it looks like the creep shifter will be slightly higher on the case than the standard H/M/L shift control. You'll have to get under there and look.
30 Yard Roll Off Dumpster (A65579)
30 Yard Roll Off...
2018 Ford Fusion Hybrid Sedan (A64557)
2018 Ford Fusion...
2013 Caterpillar 420F 4x4 Extendahoe Loader Backhoe (A64194)
2013 Caterpillar...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2021 Ford F-150...
2006 Utility Spread Axle Trailer (A62679)
2006 Utility...
2025 Swict 84in. Bucket Skid Steer Attachment (A64553)
2025 Swict 84in...
