Kubota 3710
/ Kubota 3710 #1
Mogrod
Sanford NY
Cub 2550
Does anyone know what the top speed of the Kubota 3710?
/ Kubota 3710 #2
14.4 mph hst
14.3 mph gst
That may vary with tire type.
/ Kubota 3710
The most i can go is 6 or 7 in high gear. It is the HST. Is there a range selector on this machine?
/ Kubota 3710 #4
The L3710 hst will have the treadle pedal and three ranges: High, Medium, Low
Creeper gears were an option, but I am not familiar with their operation.
/ Kubota 3710
Thanks. Not sure why I can't get it to go any faster
/ Kubota 3710 #6
If you have found the range selector and have it in high, maybe make sure the treadle isn't bent? Had a Kioti in the shop with a similar treadle pedal setup and somehow they managed to bend it where it wouldn't have full travel.
/ Kubota 3710 #7
I have an L3710 HST, 14mph is the top speed listed in the owner's manual.
/ Kubota 3710 #8
I don't think I've ever had a tractor that would reach it's rated top speed on anything except the flat paved road or a slight downhill . Certainly not going up even the slightest slope - even on a hard surface road. An uphill that I can barely detect will keep our tractors from using top gear.
/ Kubota 3710 #9
Only tractor I've ever had that had to downshifted going up hill, without a load, was a JD 3020 Propane with a powershift. Either lug it up hill at 1500 rpm in 8th or wound out in 7th.
/ Kubota 3710
It is the HST. I use the H M L. And in H I'm getting 6 or 7 mph. Is there another shifter that has a High Low range?
/ Kubota 3710 #11
I am not familiar with the creeper gear I mentioned earlier. If your machine has the option, it looks like the creep shifter will be slightly higher on the case than the standard H/M/L shift control. You'll have to get under there and look.
LONG 10 WHEEL V-RAKE (A64278)
LONG 10 WHEEL...
2012 Ford E-450 Sewer Viewer Van (A64556)
2012 Ford E-450...
2022 KUBOTA KX057-5 EXCAVATOR (A65053)
2022 KUBOTA...
2022 JOHN DEERE 17G EXCAVATOR (A63276)
2022 JOHN DEERE...
2020 KUBOTA RTV-X1140 UTV (A63276)
2020 KUBOTA...
2016 CATERPILLAR 311FL RR EXCAVATOR (A65053)
2016 CATERPILLAR...
