Kubota 2660 Engine RPM's
/ Kubota 2660 Engine RPM's #1
Popfizz7
Southern Indiana
John Deere 2032R
Hello everyone. I am new here so I apologize if I posted this in the wrong thread....
But I just bought a new 2660, FEL and 60' deck. My questions are..... what is the normal idle speed for this tractor? Mine idles at approx 1350 rpm. Also, what is the maximum rpm? I know the maximum rated rpm in the owners manual says 3200 but mine will rev all the way to 3450 at WOT. Is this ok?
Thanks in advance,
Popfizz7
/ Kubota 2660 Engine RPM's #2
The manual on my machine specifically states not to run WOT for the first 50 hours, so keep that in mind. I have been keeping mine at about 2900 when working and it does not bog, and will run it that way until broken in.
I have revved mine to over 3300 for a second in neutral, but in gear at WOT it runs at 3200. I wouldnt worry a whole lot about it now because you should not be at WOT anyways, but it would be worth a call to your dealer to make sure the governor or fuel pump is not slightly out of adjustment
/ Kubota 2660 Engine RPM's #3
Welcome Popfizz! I know you'll get the help you need. Enjoy!
