Kohler M18 engine question
/ Kohler M18 engine question #1
rtd
Athens, Ohio
Ford 3930 - Kubota L3430 - Kubota B2150 - YM155D
I removed the spark plugs from the M18 engine. They were Champion RC12YC. When I checked the engine manual, the spec was for RV17YC. I purchased a listed equivalent and found that the projection on the RC12 is 12-13mm greater than the RV17. Not knowing much about the Magnum line of engines, I was/am confused. I thought that the longer reach plug might interfere with the piston. Since the engine did run, it didn't interfere.
Has anyone had a similar experience? I could try the RV17 plugs and see what happens, but I'd like to better understand whats going on.
Thank you
/ Kohler M18 engine question #2
I'd put what the factory specs call for. Maybe someone just had the others laying around and threw them in?
/ Kohler M18 engine question #3
NGK TR4 is a good plug for these. You didn't say what the listed equivalent plug you bought was. I'd think it's one of those things that it would run with anything, but the tapered seat plugs VS the flat seats will make up for some of the length.
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
1999 AMERICAN EAGLE CLASS A MOTORHOME (A65643)
1999 AMERICAN...
2002 Pace American of Texas Trailer, VIN # 47ZA528212X020330 (A61572)
2002 Pace American...
New/Unused AGROTK YC-32G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
2018 Genie GTH-5519 (A64126)
2018 Genie...
