Kioti Old problem with KL130 loader cracks
/ Kioti Old problem with KL130 loader cracks #1
gcabinet1
Kioti CK30
Hi I am new to the forum, I have a deposit on a 2007 Kioti CK30H with a KL130 or it might be a KL130b loader
I have been reading about the problems with cracks in the cross member tube
I have several questions
1.that years were affected?
2.what serial numbers were affected ?
3. If mine was affected how do I tell if it was repaired ?
4. Where do I find the serial numbers on the loader?
Thanks for your help
/ Kioti Old problem with KL130 loader cracks #2
If you dig back in the Kioti forum there was lots of discussion on this, including a way to tell if the loader had been repaired. Good luck with your info search.
/ Kioti Old problem with KL130 loader cracks #3
/ Kioti Old problem with KL130 loader cracks #4
I have the first generation KL130 loader and it has never cracked. I asked Kioti to send me the strengthening kit, but they never did. Without a local dealer that services these tractors, customers were not to be trusted with their own welding, apparently.
I understand that, but I bought 3 new Kiotis and one new Bobcat CT230 (nearly the same as the CK30, except for loader and wiring). I wanted the strengthening kit and even planned my own upgrade.
I never did it, and never had a problem. I max out my loader all the time, but lifting is always done with forks or with a lift hook in the center.
Thanks guys much appreciated!
was your machine listed under the serial numbers that where affected? Thanks
Was your machine listed under the serial numbers that were affected? Thanks
/ Kioti Old problem with KL130 loader cracks #7
This was a big issue 15 years ago, and my unit was covered. I can't recall anything about a serial # list. The design of the loader boom included a tubular beam that tied each side together, but was welded to only one side of the boom arms. Plus, there is a huge access hole in it for hoses.
Okay thanks found out today the my machine was made after
The problem and they changed the design so it looks like I am
Okay according to the serial numbers
Thanks for the help !
/ Kioti Old problem with KL130 loader cracks #9
Does your loader use the round cross-tube that fully penetrates the 2 loader boom arms?
Yes it does
/ Kioti Old problem with KL130 loader cracks #11
That is the newer style that has no cracking problems. Built like most of the other loaders out there.
Great thanks for the reply
1996 International Water Truck with a Caterpillar Engine (A63688)
1996 International...
PVC PIPE FITTINGS (A64276)
PVC PIPE FITTINGS...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
