Kioti KB2376 Backhoe
/ Kioti KB2376 Backhoe #1
sut
corning ca.
LK3054XS
Have a oil leak at the spool on the crowd valve. This was repaired by a Kioti dealer on 7/24/12 along with the hyd. pump and the whole system was flushed out at that time. This unit has only 72.2 hours on it and started leaking again. On 4/5/13 I replaced the o-rings on both spools on the crowd valve joystick ***'y and tested it, it was not leaking oil. 4/6/13 ckecked valve and it is seeping oil again after just setting all night. Is there a way to fix problem. lesasutfin@gmail.com
/ Kioti KB2376 Backhoe #2
Most spools in hyd valves are a precision fit, and when they wear, there is no fixing them.
Some valves spools have o-ring seals on them, and they can be replaced.
A seal allows part of the spool to protrude outside the housing, where it is accessible to the actuator.
/ Kioti KB2376 Backhoe #3
Are you getting back pressure? Did they use the PB port to feed 3pt? See how many lines are hooked to the loader valve. Might be a good time to check pressure.
There is no way that this spool should be worn out with only 72.2 hours on it. I belive that it is a pressure problem. Received this e-mail from also. There was a certain vintage that had a problem of putting too much pressure on the o-rings causing them to blow out. There is a service bulletin on it that the dealer should be able to bring up. Holts LK3054xs had the problemand was a 2005 model.( ours is a 2004 model ). The solution is a 4 hour fix that Kioti came up with. Dealers were suppose to fix any tractor on the lot and call owners. They got paid for 4 hours. I am in contact with the dealer at this time.Sut
/ Kioti KB2376 Backhoe #5
Where did the e-mail come from, Kioti about the service bulletin ?
2005 International 4400 S/A Day Cab Truck Tractor (A61573)
2005 International...
Quicke Loader Joystick Kit (A63117)
Quicke Loader...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
Adams 5 Ton Fertilizer Spreader (A63688)
Adams 5 Ton...
UNUSED WOLVERINE MCB-11-48W 48" HYD 4N1 BUCKET (A64281)
UNUSED WOLVERINE...
2018 Western Star 4900 Tandem Dump (A62613)
2018 Western Star...
