Kioti just stopped...
/ Kioti just stopped... #1
OzKioti
SE Queensland, Australia
Kioti RX8030 & loader
As the title says, it just stopped for a breather. I tried to restart it, but no go - the starter motor spun the motor OK, but would not start. So I sat there, fat dumb and unhappy for a minute or two, then tried again. This time, no problem - it just started as normal!
Fuel tank was near full (I use a dipstick, as I was trained to do years ago when I started flying training in a Cessna bug-smasher - never trust a fuel gauge). I had been doing some light work with the machine (Kioti RX8030 - 76hp) and was basically idling in 4th down a very slight slope on the way back to the shed.
Any ideas?
/ Kioti just stopped... #2
Any ideas?
Well, what does it take for a diesel engine to run? Lets see... You need fuel injected at the precise time, you need air to support combustion and you need compression of the fuel air mixture. And you need the momentum of the engine running to keep or start that compression . If I had to guess I would make a guess that the fuel delivery was interrupted in some manner, from the flow from the tank (bug over hole?) or the fuel solenoid lost power or ground so the injector didn't deliver the fuel or the injector has some kind of mechanical problem (rack teeth failure), but it will be difficult to find now that it started and run again. What you have on your hands is an intermittent. And that is the absolute worst kind of problem to have. It would have been a lot easier if it had never run another pop.
/ Kioti just stopped... #3
yep, fuel starvation surely, but what caused it. The clue maybe in the statement "Fuel tank was near full" indicating that it had been refueled recently. Most likely a bit of stray dirt but how could it get past the filters? Worth a further look cause if you are relying on the engine for braking and it cuts, not nice!
/ Kioti just stopped... #5
Safety switch glitch?
That might have activated the fuel shut off solenoid that shut down the injector pump so no fuel was delivered to the injectors? Might be on to something here.
/ Kioti just stopped... #6
Did your butt come off the seat?
That could trip the seat safety. Some times if I lean to far one way mine will cut out.
Re a seat safety switch, I'm not aware of one on this machine. I often get out of the tractor (cab model) to pick up fallen branches when slashing, or after activating the 2 minute countdown timer, I might get out and do a walk-around while waiting for the turbo to cool down before shutdown.
So it must be a temporary fuel starvation situation, but why? An electrical glitch, or temporary blockage in the fuel supply system does seem likely. The tractor has done <100 hours since new in November, and remember it's our summer over here, so typical ambient temperatures are around 30C (not like the -25C you folks in some unexpected parts have had recently). Icing of the fuel lines seems unlikely. Water in the diesel? I'd think the filter would trap that if any were present.
I've talked to the dealer's workshop section, and I have the guys mobile number in case the tractor does it again and won't restart, but as kOua said, these intermittent issues are the worst ones to troubleshoot.
Edit - I've just come in for a coffee break after five hours slashing, and hasn't missed a beat!
/ Kioti just stopped... #8
I'm assuming (uh-oh) that your fuel cap is vented. Is it possible that the venting isn't working correctly creating a vacuum in the fuel tank?
The temp gauge (should I trust it?) showed normal operating temps, but I will check the coolant levels. I'll check anything which might be relevant.
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2019 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A64556)
2019 Peterbilt 579...
HOMEADE 101" X 25' TRI-AXLE FIVE SAFETY HOUSE (A63276)
HOMEADE 101" X 25'...
2016 International WorkStar 7500 T/A Dump Truck (A64556)
2016 International...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A64557)
2018 Freightliner...
