Kioti DS4110 won't start after refuel
   / Kioti DS4110 won't start after refuel #11
I HAVE A DS4110--2011--HAVE THE SAME PROBLEM. STARTS SOMETIMES AND THEN WON'T. SOMETIMES TURN KEY 6 0R 8 TIMES AND IT WILL START OR NOT. THE PROBLEM WAS A BAD CONNECTION WITH A SAFETY SWITCH--CLUTCH SWITCH. I UNDERSTAND KIOTI HAD SOME BAD IGNITION SWITCHES AROUND THAT VINTAGE ALSO. WHEN IT WOULDN'T START, I WOULD JUMP IT AT THE STARTER WITH KEY ON AND IT WOULD START. HOPE THAT HELPS.
Thanks for all of the additional suggestions. I finally got to get back out to it today. Turns out that @Snezzy had the right idea.
I checked the connector at the solenoid and it appeared to be good: one lead had constant 12v when the key is on and the other had a 12v burst for one second when the key is turned on, but the solenoid still didn't pull. A replacement solenoid also didn't pull. I then found a post from a guy saying he had a bad pull relay but could get around it by removing the solenoid, turning the key, pushing in the plunger, making sure it held, and then reinstalling it before starting. I tested those steps up to seeing if the plunger remained pulled. Bingo.
I located the relay (thank you workshop manual) and noticed that I could push the connector onto the relay an additional 1/8"-1/4". It then successfully pulled several key turns in a row and started right up when tried. I'm really thinking I've gotten this nailed down at this point and I will be getting a new relay to keep on hand in case this one gives out completely.
Turns out if I had slowed down and fully read this post, I would’ve/could’ve gotten here sooner.
Thanks!
BOMAG BW145D ROLLER (A60429)
BOMAG BW145D...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
John Deere 7410 (A53317)
John Deere 7410...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A56438)
Dual Tailwheel...
2018 Forest River Flagstaff Pop Up Trailer (A59231)
2018 Forest River...
2016 Ford F-550 Venturo HT40KXX 3 Ton Crane Mechanics Truck (A59230)
2016 Ford F-550...
