Loader Kioti CK27 Joystick installed wrong... questions
   / Kioti CK27 Joystick installed wrong... questions #21
Good for you Dav glad you tackled and solved the issue.
   / Kioti CK27 Joystick installed wrong... questions #22
Update: Turned control box around, float is now in correct spot.
Awesome!! I Haven't messed in there to know much about how that cable system worked (push/pull vs pull/pull or whatever) but I just had a gut feeling it was cable related somehow.
I'm glad you figured it out and got everything fixed up.
And thank you for detailing what you found & Did. I'm sure it will help others down the road.
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
M998 (A55852)
M998 (A55852)
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
Pull-Behind Batwing Rotary Brush Cutter Attachment (A59228)
Pull-Behind...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
TANK MANIFOLD (A55745)
