King Kong Teeth
/ King Kong Teeth #1
fishfactor
Monroe, NC
(2) 2014 CAT 299DXHP / FECON
I like to post my thoughts good and bad on products that I try. Hopefully it will benefit someone at sometime.
The previous set of teeth I ran on our Gyro Trac GT25 came from King Kong Tools. They just came off and here are the results.
Life - I was happy with the life at almost exactly 100 hours.
Cut - I was happy with the performance. Seemed to cut just as fast as Gyro Trac teeth.
But.... if you plan on using them, plan on switching for good. The tab on the back of the tooth is a little smaller than the Gyro Trac teeth and doesn't completely fill up the pocket. The extra space in the pocket gets packed full of debris. The debris is packed so tight that you need a hammer and small chisel or screw driver to get it out in order to put a Gyro Trac tooth back on, best case. I had a few pockets that were deformed. I had to use a die grinder with a small endmill to reshape the pocket so the Gyro Trac Teeth would fit. Luckily it didn't ruin the base. Those are no fun to change.
I had been warned about problems associated with the pocket/tab by a member on this board, but I already had them on the machine so it was too late.
So, if you decide to try them you will probably be happy with the teeth in general, but plan on making the switch forever. I would imagine that these problems would be compounded the longer you use them and eventually you would not be able to switch back without replacing all of the bases.
/ King Kong Teeth #2
Had the same problem with king kong tools on my Denis Cimaf head, but never became an issue. U need to try the BFS533P has carbide hard facing i got 175hrs out of the last set i used. They also keep a sharp edge than the hard steel tools, i sharpened them round 20-30hrs depending on the material i was grinding.
/ King Kong Teeth
I tried some of them spaced equally on the head. Cut was slower and when you factor all things in, the life difference didn't equal the price difference. If you don't like to sharpen they may be a good choice. I don't mind sharpening and like mulching a 24" hardwood in 10 minutes :)
/ King Kong Teeth #5
Fecon Can't Hang with a cimaf or gyro trac Head:D
/ King Kong Teeth #9
looks like a nice cimaf head on your rayco:laughing:, next time buy a fecon machine and it would have sold by now:confused2:
/ King Kong Teeth
1000 HOURS ON WHAT KIND OF HEAD??
Smooth rotor Fecon head painted black and sold as Bobcat Brand. We're not in sand much at all which helps.
/ King Kong Teeth #13
Fish just buy the teeth directly from Robbie or Fred they are priced competitively and are a OEM solution.
/ King Kong Teeth #14
Jamesn,
My Rayco c140 has a Rayco head on it with a Fae Rotor, i do have Quadco Chippers on it man wat a difference! Just sold my Cat 297c it had a Denis Cimaf 180d head on it. Lookin to down size to one machine inbetween my Cat 297 an Rayco 140, maybe a Rayco C100 or Lamtrac 6125 with Cimaf or gyro head. anyone intrested in my Rayco 140?
/ King Kong Teeth #17
also rowmec, in conroe does sell some sort of carbide teeth for a cimaf head if you want their number let me know and i will pm it too you. dont know the price thats conroe, texas
/ King Kong Teeth #18
how much does a set of teeth cost for a cimaf head? and how many hours will a set of cimaf teeth last in the sand? how many hours will you get from a set of cimaf teeth in rocks? i am just curious
/ King Kong Teeth #19
Sandy conditions anywhere from 60-80hrs wouldn't even try to cut with the cimaf in rocks unless i threw on some carbides. For regular Cimaf teeth round $50 a tooth, for harden Steel Round $55, but haven't bought them in a while so they could be more or less.
/ King Kong Teeth #20
And remember, while offering a long life tool in a double carbide or a stone tool, Fecon has the fast cutting knife also.
1143 (A63745)
1143 (A63745)
2022 EZ-GO ELITE...
2024 FORD F350 4X2 CREW CAB & CHASSIS PICKUP TRUCK (A67148)
2024 FORD F350 4X2...
2011 Jeep Grand Cherokee Laredo SUV (A64557)
2011 Jeep Grand...
1991 Brenner 307 SS Single Comp Insulated T/A Chemical Tanker Trailer (A64194)
1991 Brenner 307...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
