Keeping a cylinder from bending
   / Keeping a cylinder from bending #31
If your going to redesign the unit or the cylinder can you just cut the mount and move it so it is at the limit of the cylinder travel and reweld,
   / Keeping a cylinder from bending #32
It does not need a return to the tank,
as the cylinder can at a given pressure by pass to the opposite hose, thus if the cylinder is compressed/extended to over design load it moves as the oil is passed from one side to the other via the cushion valve, (just as if one hooked a hose from one end of the cylinder to the other, (but with resistance that is set by the user via the valve
The problem being that the two sides of the cylinder have different volumes, so there is a limited amount of relief available when the valve is closed unless you have a tank line.
Aaron Z
   / Keeping a cylinder from bending #33
Yeah, that's right. Since the fluid is essentially not compressible, there is no relief available when the valve
is closed. The 2 different volumes require that fluid must go thru the valve for the cylinder to move.
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
2017 Caterpillar D5 K2 LGP (A55218)
2017 Caterpillar...
2014 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A55788)
2014 Chevrolet...
2019 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A54607)
2019 FREIGHTLINER...
2019 JOHN DEERE 350G LC EXCAVATOR (A52705)
2019 JOHN DEERE...
