aczlan
Good Morning
- Joined
- Mar 7, 2008
- Messages
- 17,540
- Tractor
- Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
That would only work if you have gravity pushing down on the cylinders. Otherwise, it would be "stuck" in extend position.While researching a hydraulic cylinder application, I came across some information about cylinders designed such that just before they are fully extended, the retract port is exposed so that further extension pressure just bypasses back to the reservoir. Don't know if all cylinders are designed this way but if so, your solution may be nothing more than a clevis adjustment or mounting point adjustment so that your mechanism is in place just as the cylinder bottoms out.
Aaron Z
