Keep current truck forever or try to afford a new one every 5-10 years?
/ Keep current truck forever or try to afford a new one every 5-10 years? #121
I know that my 5.9 Cummins gets 20 mpg and my neighbor has the same truck with a V8. Not sure of the size. He only gets 14 mpg. And the high mileage resale value does make up for the initial higher purchase price.
5.9 doesn't have all this new emissions stuff though. I had a 5.9 and they were great on fuel.
Try comparing a new 6.7 SCR/DPF. They get as bad as 11 US MPG towing.
Besides my big trucks I used to haul RV's from the factories with one tons. I know all about what they REALLY get for mileage, not what the marketing department tries to sell you.
/ Keep current truck forever or try to afford a new one every 5-10 years? #122
You are right about resale though.....diesel will be worth more. But so is maintenance, fuel and the purchase price. And all the downtime you will get with all your NOX sensors and DPF issues, LOL
/ Keep current truck forever or try to afford a new one every 5-10 years? #123
Well I don’t have any experience with the 6.7, just the 5.9, so I’m sure you’re right. I will keep the 5.9 as long as possible.
/ Keep current truck forever or try to afford a new one every 5-10 years? #124
Maintenance on the 5.9 is negligible. Annually, I change air and fuel filters, and oil/filter change according to miles. I can do everything at home. I know that’s not easy with the new powerstrokes, IDK about the new Cummins or Duramax?
/ Keep current truck forever or try to afford a new one every 5-10 years? #126
07 5.9 Cummins 130K I'll probably keep it till the very end.
Mine is also an 07 5.9 Cummins. The last year those were available. Everyone wants these. I’m keeping mine also.
/ Keep current truck forever or try to afford a new one every 5-10 years? #127
Been running a 6.7 for 3 years. Zero issues, except factory warranty required replacement of my pump. There was nothing wrong with it, they told me bring it in for a new pump. Safety issue with bad CP-4 pumps.
Emissions system has been fine so far, but only 40K miles.
Tows/pulls like the truck I always wanted.
I get about 14 around town/towing and thats with 4.88’s.
/ Keep current truck forever or try to afford a new one every 5-10 years? #128
Another bad thing about these new emissions diesels is if you don't drive them often which I don't use my pickups often, is DEF fluid deteriorates over time. So if you aren't using and replacing it with fresh stuff, eventually you are going to have issues.
The new diesels need to be run hard and steady.
That is true. The DPF also needs to be super heated regularly to keep the particulate burned off. You don’t want a post emissions diesel for a grocery getter. You need to use them for what they are made for.
Emissions destroyed the diesel truck as a recreational vehicle.
/ Keep current truck forever or try to afford a new one every 5-10 years? #129
Good plan to keep that. That's what I had. 07 Megacab dually. They only had a catalytic converter. Then replaced it with a 6.0 Ford Powerstroke because it was way better on fuel, but then it blew up twice. LOL
/ Keep current truck forever or try to afford a new one every 5-10 years? #130
Good plan to keep that. That's what I had. 07 Megacab dually. They only had a catalytic converter. Then replaced it with a 6.0 Ford Powerstrokebecause it was way better on fuel, but then it blew up twice. LOL
Man were those things a BIG problem.
/ Keep current truck forever or try to afford a new one every 5-10 years? #131
And that's my problem. My pickup sits long periods because I was ALWAYS either in my big truck and out on the road.
So to have a new diesel that will only be run every second or third week, that tank of DEF would be in there forever before I ever burnt it off.
Like you say, they ruined the diesel for those of us that let them sit weeks at a time.
/ Keep current truck forever or try to afford a new one every 5-10 years? #132
The only alternative for someone who wants to own a diesel for ”fun” or the joy of the way they drive is to buy a pre-‘08.
Deletion of a new one just seems problematic.
/ Keep current truck forever or try to afford a new one every 5-10 years? #134
Funny thing was I had two friends with 6.0 Powerstrokes and they are the ones that NEVER change oil or do any maintenance and those trucks are still going and never failed.
I was religious with my maintenance, even got rid of the Motorcraft Gold coolant that was the biggest cause of the head gasket issues, but like I said I programmed it and it was just tooo much for it.
My second one in the F550 was also programmed but it was studded.
My 6.7 sits quite a bit. But when I run it it get to run for a bit. It is a 2016 and has 40k miles. I put in the 2 gal. containers of DEF so it stays pretty fresh. In the winter my DEF system pretty much stays off most of the time with frozen def. That has been the only codes that it has thrown and I just clear them when it gets warmer.
/ Keep current truck forever or try to afford a new one every 5-10 years? #136
The problem with Toyota and Nissan trucks is they only offer 1/2 tons, nothing more heavy duty.
Nissan has an Titan XD that has more capacity than the Titan. The XD is a bigger vehicle and the frame is different. I don't need a F350, or a F250, anymore so a regular truck works. I feel for anyone that needs a F250/F350 size truck due to the current prices.
/ Keep current truck forever or try to afford a new one every 5-10 years? #137
Anecdotal, but I've seen plastic components get brittle on vehicles after the last 20 years or so, maybe even in less time, but before they needed work. Snap fits, connector locks, even light structural components. Don't know where that will end in trying to keep a vehicle for decades. I guess they don't make plastic like the used too...
Yeah, the plastic gets brittle and breaks easily, even if one is careful. :(
/ Keep current truck forever or try to afford a new one every 5-10 years? #138
In an effort to be more environmentally friendly the manufacturers are now making the insulation that covers the wiring in vehicles out of soy instead of rubber. That's resulted in huge problems with rodents eating the insulation off the wiring. The other day I was reading an article which stated that tire manufacturers, also to be more environmentally friendly, are experimenting with making tires from soy and other plant products.
So if one day you find your new tires have been destroyed, chewed up by woodchucks or ground squirrels or rats...now you know why. They taste good!
/ Keep current truck forever or try to afford a new one every 5-10 years? #139
I was able to peel up the sill plates on my 2003 F450 a few weeks ago without breaking the plastic tabs. The metal clips were totally rotted but I saved the plastic!
I'm at the position where as I stated, the big trucks are too expensive to replace. I will fix my old trucks up until I physically can't do it anymore. The daily driver will get replaced as needed. Of course that means I need to keep a herd of vehicles. But that is also my particular vice.
/ Keep current truck forever or try to afford a new one every 5-10 years? #140
That's been happening for decades. On occasion loggers have bone back to the woods after spring breakup to find their skidder tires have been chewed. At $5000/tire, that can get expensive.
2014 NISSAN NV CARGO VAN (A59905)
2014 NISSAN NV...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
SWICT 84" SKID STEER BUCKET (A60430)
SWICT 84" SKID...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
1408 (A57192)
1408 (A57192)
