Kaboto 3 point
/ Kaboto 3 point #1
KUECKER
I'm having problems with the 3 point. When engaged the 3 point will very slowly raise. If there is any weight on the 3 point it will not raise. I can stop the 3 point from raising just by holding down on the arms. However, if the 3 point is in the up position I can not push it down unless the lever is disengaged. I don't have any problem with the loader, it works fine.
/ Kaboto 3 point #2
What model tractor do you have? Does it also start to go down on its own a little while after you raise it?
/ Kaboto 3 point #3
Also did you just buy the tractor or have you owned it for a while and the problem just started?
20 Ton Air/Manual Hydraulic Bottle Jack (A64557)
20 Ton Air/Manual...
2011 FORD F-550 SUPER DUTY (A67714)
2011 FORD F-550...
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
2025 JMR Stump Bucket Skid Steer Attachment (A66734)
2025 JMR Stump...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A65053)
2019 VOLVO A45G...
CAT D6T SU Blade (A68134)
CAT D6T SU Blade...
