Kaboto 3 point
/ Kaboto 3 point #1
KUECKER
I'm having problems with the 3 point. When engaged the 3 point will very slowly raise. If there is any weight on the 3 point it will not raise. I can stop the 3 point from raising just by holding down on the arms. However, if the 3 point is in the up position I can not push it down unless the lever is disengaged. I don't have any problem with the loader, it works fine.
/ Kaboto 3 point #2
What model tractor do you have? Does it also start to go down on its own a little while after you raise it?
/ Kaboto 3 point #3
Also did you just buy the tractor or have you owned it for a while and the problem just started?
2001 Freightliner FL112 T/A 5 Car Hauler Truck (A68183)
2001 Freightliner...
CATERPILLAR H95-S HYD HAMMER (A65056)
CATERPILLAR H95-S...
2016 Mazda Mazda 6 Sedan (A66738)
2016 Mazda Mazda 6...
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
PALLET OF LIFTING STRAPS (A68842)
PALLET OF LIFTING...
PORTAPOTTY (A68842)
PORTAPOTTY (A68842)
