Kaboto 3 point
   / Kaboto 3 point #1
KUECKER
I'm having problems with the 3 point. When engaged the 3 point will very slowly raise. If there is any weight on the 3 point it will not raise. I can stop the 3 point from raising just by holding down on the arms. However, if the 3 point is in the up position I can not push it down unless the lever is disengaged. I don't have any problem with the loader, it works fine.
   / Kaboto 3 point #2
What model tractor do you have? Does it also start to go down on its own a little while after you raise it?
   / Kaboto 3 point #3
Also did you just buy the tractor or have you owned it for a while and the problem just started?
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
2003 Big Tex 10PI...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56438)
2023 Kubota...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
