JX80
wadem
Mesick, MI
IH966,Farmall F12, Case 430, CasiIH jx80
Where is the adjustment for how fast the 3 point goes down on 2008 CaseIH JX80?
I have moved draft control all over the place and still very very very slow to lower 3 point. Trying to use backblade on it.
There should be a valve on the floor or in the panel behind your feet that controls the drop rate of the 3 point.
I'm pretty sure there is a cable for the lift-o-matic switch on the hitch valve. Hitch valve is under remote valve on top pto. Can adjust the cable to speed drop rate.
/ JX80
Thanks boudreaux81. I found that and adjusted it and you were spot on. Finally someone who actually knows.
/ JX80
now for another problem. It seems to be in 4 wheel drive all the time. Lever moves but obviously won't disengage front drive
Yes as previous comment check see if shaft on side transmission is moving along with handle and not just the linkage. Could very well be broken roll pin. Sometimes you have to be slowly moving to disengage also.
Then also pinbolt Partno 5129031 that anchor the returnspring partno 5129033..........pinbolt broken off ? spring still there ?
2012 Allmand Nite-Lite Pro II 8KW Towable Light Tower (A64194)
2012 Allmand...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
2003 Freightliner FS65 Thomas School Bus (A64194)
2003 Freightliner...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
2016 Freightliner M2 106 S/A Day Cab Truck Tractor (A64194)
2016 Freightliner...
2022 Mercury Verdado 300HP Outboard Boat Motor (A64557)
2022 Mercury...
