jx 75 white smoke?
/ jx 75 white smoke? #1
rbg60
NW Illinois USA
IH 2400 case Ih Jx75
Hello
I have a jx75 that I bought three months ago.It has been a good tractor so far with 70 hrs. on the meter.My only concern is sometimes starting or when its working hard will let out a puff of white bluish smoke.Is this common or should I be concerned?This is my first diesel so I'm not sure what to expect.Is the jx diesel supposed to be a good engine?Any replies would be appreciated.
Thanks Rex
/ jx 75 white smoke? #2
If it really is "white" smoke, it might mean coolant in the cylinders. But if it is bluish white it probably means the rings are not seated all the way yet, with only 70 hours this may be the case. If it just puffs a time or two under a heavy load then I wouldn't worry about it much. KDJ j48
/ jx 75 white smoke? #3
check your head gasket. do a compression test on all your cylinders. note if there is a difference in any of the cylinders. all should be within 10 lbs of each other. if not you may have a leaky head gasket or a valve not seating propertly. if a valve is not seating you should be getting slight to loud backfire thru the intake or exhaust.
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63118)
2023 Kubota...
2016 Chevrolet 2500 HD 4WD (A63118)
2016 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
