jx 75 white smoke?
/ jx 75 white smoke? #1
rbg60
NW Illinois USA
IH 2400 case Ih Jx75
Hello
I have a jx75 that I bought three months ago.It has been a good tractor so far with 70 hrs. on the meter.My only concern is sometimes starting or when its working hard will let out a puff of white bluish smoke.Is this common or should I be concerned?This is my first diesel so I'm not sure what to expect.Is the jx diesel supposed to be a good engine?Any replies would be appreciated.
Thanks Rex
/ jx 75 white smoke? #2
If it really is "white" smoke, it might mean coolant in the cylinders. But if it is bluish white it probably means the rings are not seated all the way yet, with only 70 hours this may be the case. If it just puffs a time or two under a heavy load then I wouldn't worry about it much. KDJ j48
/ jx 75 white smoke? #3
check your head gasket. do a compression test on all your cylinders. note if there is a difference in any of the cylinders. all should be within 10 lbs of each other. if not you may have a leaky head gasket or a valve not seating propertly. if a valve is not seating you should be getting slight to loud backfire thru the intake or exhaust.
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
2016 WILDWOOD TRAVEL TRAILER (A63569)
2016 WILDWOOD...
2013 Kuhn Krause 80-40 Vertical Tillage Tool (A63116)
2013 Kuhn Krause...
High Hood All Aluminum Timpte 720 Trailer (A63118)
High Hood All...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
Kuhn Axis 50.2 H-EMC-W Fertilizer Spreader (A64047)
Kuhn Axis 50.2...
