Just how good is 4 wheel drive
/ Just how good is 4 wheel drive #61
Well, it's a very simple construction, most tractors does have electric engagement of PTO and it's the same principle, so the cost of having a lot more safety and ease of use is quite low.
But maybe it's very little new thinking on those small tractors.
Even my Kioti CUT which has electric engagement of the 4WD with a simple rocker switch on the dash does not engage the 4WD by pushing on the brake pedals, even though there is a microswitch on the brake pedals that lights a light on the dash when the brake pedals are engaged and the parking "pawl" lever is engaged. So 90 percent of the hardware is already there, but it does not have that feature like the big tractors do.
/ Just how good is 4 wheel drive #62
Look at it this way. All tractors have one wheel drive. Then when you need more traction, you push down on the lever at your feet the locks the rear differential and now you have 2 wheel drive. A so called 4 wheel drive tractor is actually 2 wheel drive all the time, so when you need more traction, you push down on that lever to lock the rear differential, and now you have 3 wheel drive.
It's a significant improvement. I have both types of tractor and it's night and day better getting around in poor conditions with three tires working over 2. In dry conditions, and where you don't really need the most traction possible, 2 wheel drive works fine. I just learned years ago to never take any chances with the 2 wheel drive tractor after it rains. I make sure everything is rock solid dry first!!!
Well...yes & no.
With 2wd: When one tire is spinning and the other is just sitting there, I guess you could also call that Zero wheel drive, cause you ain't driving...you're stuck!! :rolleyes:
The motionless tire applies the same amount of torque to the ground as the spinning one....it's just that the spinning tire doesn't demand very much torque (because it's spinning in loose mud) and this isn't enough torque to make the other stationary wheel "turn" and propel you forward.
If locking differential is not possible, a tap of the steering brake on the spinning side increases the torque required to spin and this ups the torque delivered on the stationary side too...sometimes enough to get that tire to turn (propel) the tractor forward..(or spin and turn that side to muck too!)
On my 4wd tractor they put some stops on the "frame" so that front axle doesn't pivot as much as I expected, or as much as the 2wd version probably does. Not sure why? I soon learned that when going through a ditch at 45 degrees you can get opposite corners off the ground (1 front, 1 back tire) and your "4WD" quickly becomes "ZeroWD".
...until you step on differential lock and use "1WD" (1 rear wheel).
/ Just how good is 4 wheel drive #63
I have electric engagement on my riding mower. It's OK for a riding mower - no problems in the 17 years I've had it. The Kubota M6040 is a totally different story. Both 4WD & PTO are mechanical engagement. I don't think I can "feather" the 4WD engagement. It's either in or out. The PTO engagement can and alway is feathered into full engagement. It's a very nice feature that ensures smooth, gentile engagement of PTO implements.
/ Just how good is 4 wheel drive #64
Hydraulic 4WD engagement is very old tech, no problem at all on tractors since probably the seventies.
/ Just how good is 4 wheel drive #65
I can't even conceive of using a two wheel drive tractor, unless one's property was very flat. Having been somewhat use to two wheeled tractors, in an area that was flat, and then living in an area that was not so flat, and using an FEL on those not so flat areas, a 4 wheeled tractor is twice the utility of a two wheeled tractor. I would never consider a two wheel tractor any more. It very much just depends on the terrain, and snow seasons you are working with. For me, there is no going back to two wheel drive. :)
/ Just how good is 4 wheel drive #66
My 4WD is a lever by my heal. Is it possible in a runaway situation that I might be able to pull it up to engage 4WD? Maybe that is not what you are saying.
/ Just how good is 4 wheel drive #67
The nicest thing about many of them was they actually are in 4wd till you turn it off,
my branson 8050 takes power to turn it on, it also engages it automatically if you press both brake pedals at the same time.
/ Just how good is 4 wheel drive #68
My 4WD is a lever by my heal. Is it possible in a runaway situation that I might be able to pull it up to engage 4WD? Maybe that is not what you are say8ng.
Not likely. You will never get the gears to mesh. Just exactly how the big tractors with their electric over hydraulic engagement works, I am not totally sure. There may be synchronizers at work here. Might be why it is not available on CUTS or SCUTS. Engaging 4wd on the "fly" has been available on our pickup trucks for several years, but remember it was not always thus. Could you put your 1958 power wagon in 4wd on the fly? I don't think so. Tractor technology at least as it relates to drivelines is pretty rudimentary and ancient technology. Except when you get into big expensive tractors.
/ Just how good is 4 wheel drive #69
Most of them are multiple disk wet clutches, many of the larger Ag ones use the hydraulics to disengage.
A 58 power wagon could be shifted into 4wd while being driven, most of them didn't have free wheeling hubs so they could be shifted any time as long as you weren't spinning.
Any 4wd truck if the hubs were engaged could be placed into 4 wd while moving.
/ Just how good is 4 wheel drive #70
In winter while plowing there have been a few times when my glove caught on the lever and put me in 2WD unawares.
After the panic feeling subsides I put it back in. The panic is me thinking I have no clutch. It is that dramatic.
2WD is only for when I am mowing flat areas.
/ Just how good is 4 wheel drive #72
Yes this happens to me on my steepest hill. My wheels loose traction and I slide down basically every time. No load in bucket just mowing.
I want to make sure it's safer in 4x4?? I was thinking that maybe, it's like driving in snow, where if you slam on your brakes, your front tires grab better than the rears and your rear end wants to swing around sideways.
Does that not happen?
Yes that can and does happen! It痴 not from the brakes however when it does it痴 from the wirght being off center and the rear can come around. Going forward down hill with the incorrect counter wieght on the rear and thinking your safe because you have it in four wheel drive just means your overloading your front axel and it痴 not making you any safer.
The proper way to decend the hill is to turn around and back down! Four wheel drive is not a cure for the incorrect wieght on the rear it痴 just a way to do things incorrectly and get away with it till he front axel breaks from overloading. Many think they blow out parts on the front axel due to having a loader up there but the reality is they have used the loader with incorrect counter wieght one too many times putting undue stress on it.
/ Just how good is 4 wheel drive #73
I'll tell you how good. I sold my JD 4230C 2wd, with front end weights at 100 hp and bought the 6530C 4wd, with the loader as the front end weight, downsizing since semi retiring from farming. I can run the same implements with the 6530 in 4wd as used with the JD, just as fast on a lot less fuel.
/ Just how good is 4 wheel drive #75
Today I plowed for the first time with my tractor, was able to also plow down my side drive which is a 1 story decline (walkout basement) and make it back up. Previously, I tried doing that one time with the plow mounted on my 2wd gt with locking differential...never made it back up. So how good is 4wd? For me, it's difference between getting back up the driveway or not.
/ Just how good is 4 wheel drive #76
To me, 4wd is like two people walking. No problem. Now 2wd is like one person carrying the other person.
/ Just how good is 4 wheel drive #77
I took mine out of 4 wheel drive one time, just to see what 2 wheel drive was like, other than that 10 minutes it stays in 4 wheel. The only level spot on 32 acres is where I park the tractor so I can check fluid levels.
/ Just how good is 4 wheel drive #78
It's like 2 people carrying a couch, except 1 of them ain't carrying shyte. :D
/ Just how good is 4 wheel drive #80
In 2wd, my tractor will break traction long before running out of power to perform the task at hand. In 4wd, it will typically bog the engine down before breaking traction. Unless I am mowing the lawn or traveling up the road, I take advantage of the 4wd and it's additional capability for my machine.
SKID STEER MOUNTING PLATE (A60430)
SKID STEER...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
(2) USED 3500 LB TRAILER AXLE W/ BRAKE (A60432)
(2) USED 3500 LB...
(APPROX.64) 2X6X8 NO.2 PRIME LUMBER (A60432)
(APPROX.64) 2X6X8...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
