Just how good is 4 wheel drive
/ Just how good is 4 wheel drive #51
Well, next time you buy a tractor, be sure it automatically engages 4WD when you brake.
/ Just how good is 4 wheel drive #52
I would not even consider 2wd in my part of the country. Fine for field work, not fine for anything else.
Have to agree with this statement. It is really needed in my area.
/ Just how good is 4 wheel drive #53
Benefits of having MFWD that may not have been mentioned,
front end weight carrying when equipped with FEL
the front axle itself is usually more robust than the 2 wheel drive tractor front axle
May support more weight when travelling over rough ground when a tractor is operating with a heavily loaded FEL.
Some MFWD front axles are also equipped with larger front tires and wheels than the 2 wheel drive counterparts which can make for a smoother ride to.
/ Just how good is 4 wheel drive #54
How about the rest of you? Do you use 4WD "most" of the time, or only when you feel you really need it?
You can turn if off??? :rolleyes:
Actually, I do turn it off when I'm on pavement, which isn't often. Otherwise it's always on. Most of our place is pretty steep -- the only level areas are the small parking areas at the house and barn. No lawn to tear up, so that's not an issue.
/ Just how good is 4 wheel drive #55
My deep seated fear is that I will forget to go into 4WD on that hill until it is too late. I kind of wish there was some kind of red flag warning, "Hey, remember, you're only running on rears now!"
Yes, that is how it happened to me... 2 or 3 times. "I forgot!". Whooo Hoo... what a ride.
/ Just how good is 4 wheel drive #56
Look at it this way. All tractors have one wheel drive. Then when you need more traction, you push down on the lever at your feet the locks the rear differential and now you have 2 wheel drive. A so called 4 wheel drive tractor is actually 2 wheel drive all the time, so when you need more traction, you push down on that lever to lock the rear differential, and now you have 3 wheel drive.
It's a significant improvement. I have both types of tractor and it's night and day better getting around in poor conditions with three tires working over 2. In dry conditions, and where you don't really need the most traction possible, 2 wheel drive works fine. I just learned years ago to never take any chances with the 2 wheel drive tractor after it rains. I make sure everything is rock solid dry first!!!
/ Just how good is 4 wheel drive #57
I use 4WD when the situation calls for it. Otherwise - I'm in 2WD. I have 80 acres of virgin open range land. A few tractor tread marks here or there sure isn't going to upset anything.
/ Just how good is 4 wheel drive #58
My tractors are not the newest, that is a feature these days?
/ Just how good is 4 wheel drive #59
Nope. not for the size of tractors most of us have. Under 60 horsepower, (CUT or SCUT) Never seen it on any brand/model. Large tillage tractors will have features like that.
/ Just how good is 4 wheel drive #60
Well, it's a very simple construction, most tractors does have electric engagement of PTO and it's the same principle, so the cost of having a lot more safety and ease of use is quite low.
But maybe it's very little new thinking on those small tractors.
Giyi KH72 QA 72" 4-in-1 Bucket (A60463)
Giyi KH72 QA 72"...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
Iranch IRMC High End Massage Chair (A60463)
Iranch IRMC High...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
