John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,757
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
I always attributed the curve cuts to uneven wear on the bar, actual letting teeth run not square to bar.... Spent some to squaring bar and it seems to help, still at a loss to figure out actual problem... Never thought much it to be a actual chain problem...I also flip the bar each time I do a chain ....
Dale
That can be a cause of a saw cutting on a curve. There are lots of ways a bar can get worn unevenly. Three common ones are: (1) not enough oil on the bar and chain, (2) continuing to cut when your chain is dull - often the teeth on one side will get more dull than the other, especially if you hit something other than clean wood, wearing the bar more on one side than the other (3) chain sharpened improperly, causing the teeth on one side to get more of a bite than teeth on the other - this makes the saw want to cut in circles, yet the bar in the kerf (or the operator by exerting pressure) tend to try to make the saw cut straight, putting more pressure on one bar rail than the other. Getting a pinched bar can often cause uneven wear as well (and often overheats the bar if you continue to cut with it, destroying the temper and leading to faster wear).
