just got my chain back from being sharpened.....
   / just got my chain back from being sharpened..... #71
The raker controls the depth of the cut, if you aren't taking them down then how well does it cut by the time the chain is almost worn out?
I have no problems. I tried once by eye but I took too much off and made the chain too grabby. I'm sure I'm giving up some performance but I also don't believe that a chain with it's teeth sharpened near to the end of their life will not cut if you leave the rakers alone. I only run Sthil full chisel chains and I'll keep sharpening the chain until I hit the scribe line so it's not like I'm not getting the full life out of the chains. But I also am not in a hurry. I mostly use my Dolmar 7900 so HP isn't an issue. I just let the saw do the work and watch the chips fly out. Every 2nd tank of gas I give the chain a quick touch up (or if it feels like it's cutting slow).
   / just got my chain back from being sharpened..... #72
I’d rather have a grabby chain vs one that’s sharp and won’t cut.
   / just got my chain back from being sharpened..... #73
That's why they make a raker gauge. I did the same thing, and it took a few sharpenings to bring it back. Yet running a dull saw is too fatiguing to me... and filing the rakers is part of sharpening the chain.
   / just got my chain back from being sharpened..... #74
I agree, the rakers have to be filed down as you sharpen the tooth, IF you expect the chain to cut well.
SR
   / just got my chain back from being sharpened..... #75
Also depending on tooth you need to remove the gullet as well such as on a square tooth. I normally do them every 4 to 5th grinding as well as the depth gauges self feeding is a must if you’re in a production environment why be tired at the end of the day.
   / just got my chain back from being sharpened..... #76
I also profile the front edge of the rakers as they start to get filed flat and start developing a squared off leading "corner" that causes added grabbing. You can take a small flat hand file and radius that front corner down in 10 seconds per rake and allow it to have a sloped front edge instead a hard corner. You'll still have your newly trimmed flat peak, but get rid of that sharp leading corner. It makes me feel better about my chains.... I also use that newfangled thing that does the rakers along with the teeth at one time. I used to hand file the teeth and then use a raker file guid and flat file the rakers in a second pass. Now it is so quick and easy to spend 5 minutes before each day of cutting and "tweak and peak" the chain that it is crazy not to have this new style file system.
I use the Pferd file rather than the Stihl branded one. Man, that is a game changer for simplicity and effectiveness.
Amazon.com : Pferd 1731 Sharp CS-X Chain Saw Sharpener : Chain Sharpeners : Garden & Outdoor
   / just got my chain back from being sharpened..... #77
You're not the first person in this thread to mention that system, I'll have to check them out. I just started rounding off my rakers as you said... I"m not sure how much difference it makes but it sure looks better.
   / just got my chain back from being sharpened..... #78
Always been my view that anyone who takes their loops to someplace to be sharpened has deep pockets anyway so it don't matter how much they grind off a chain because being flush with money. they can afford it... Me, I cannot, why I do my own. In fact, just did 4 loops yesterday and set the rakers too.
   / just got my chain back from being sharpened..... #79
One in the same actually. Just different colored handles. (removed) and Stihl are identical, except the price.
The'P' is silent. It's (removed).
   / just got my chain back from being sharpened..... #80
I have the Stihl model. The only thing I find wrong with the tool is the grip. It just isn't very comfortable to use. Maybe it's just me. However, the concept is great. It does a good job of keeping my chains sharp enough for the hardest wood I've cut: pacific madrone.
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
HELI 5K FORKLIFT (A58216)
HELI 5K FORKLIFT...
2004 DITCH WITCH 3700 RIDE ON TRENCHER (A52709)
2004 DITCH WITCH...
2018 International DuraStar 4300 TMA Attenuator Truck (A55973)
2018 International...
2013 CHEVROLET SILVERADO EXT CAB TRUCK (A58375)
2013 CHEVROLET...
2023 Kubota KX057-5 Compact Excavator (A56436)
2023 Kubota...
