Just got first TIG rig!
   / Just got first TIG rig!
7 pin vs 6 makes it more difficult. Miller Torch is only "one connection" power+gas.
What about the Longevity kit, $900 for everything but the Argon bottle.
   / Just got first TIG rig! #52
Sodo, by looking at the Everlast 185 manual, the Pins are different on the pedal. Yours is 6 pin and the Everlast is 7 pin. Also the Everlast torch has a separate gas connection, and power connection. Is your miller just one connection for both power and gas?
Sodo has the "flow thru Dinse "(power and gas)
Terry
   / Just got first TIG rig! #53
Sodo as SA mentioned, have you tried lift arc? I think your machine has it.
Terry
Terry you're right MultiMatic200 does have Lift start.
In fact I'm thinking of changing my screen name to "Lift Arc" :D :laughing: :laughing: :laughing: :laughing: :laughing: Wait let me Google that first it kinda sounds like some stage of a deviant reproductive maneuver,,,,
Tried lift start tonite and it is MUCH better! This was pretty darn easy. Its 3/8" stainless steel hydraulic tube, about 18ga. No filler rod. Another problem I'm finding with TIG, I can't see. Need some kind of cheater lens. I haven't yet learned to extinguish the arc by letting up on the footpedal just pull back. Will try to add that in too. This is too much fun. James and Terry, ( & SA ! :thumbsup:) thanks for getting me going on this!
444727d1445492321-just-got-first-tig-rig-3_8tubet-jpg
444728d1445492321-just-got-first-tig-rig-lift_arc-jpg
   / Just got first TIG rig! #56
That looks pretty good!:cool: See you're getting the hang of it. Now onto open root pipe welding.:D
   / Just got first TIG rig! #57
That's looking pretty good! +1 on the cheater lens. I can't weld without them.
   / Just got first TIG rig! #58
Wow. Lookin real good, Lift Ar.. Er Sodo!
Cheater lenses are cheap. Buy one of each strength. Try them all at different situations.
( trying to think of some Shield/ Lift witticism but too early so I won't bother :))
Terry
   / Just got first TIG rig! #60
Piece of advise about the cheater lens, dont bother, just go buy some of those cheap reading glasses. I have the cheaters in my hood which means nobody else can weld with it. That sounds good, but whenever I use it, I have to take off my bifocals and set them up out of the way and when I get thru welding, I cant ever find where I laid them.
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
CFG Industrial Q.A Hydraulic Breaker (A50121)
CFG Industrial Q.A...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
KJ 33'x25' Double Garage Steel Barn Shed (A50121)
KJ 33'x25' Double...
