Just bought a F3060!
   / Just bought a F3060! #61
The problem with the engines in the mowers, unlike the ones in my big tractors is, they don't have internal balancer shafts, consequently they tend to have harmonic vibration and that is a weld killer. I kicked up the base idle on mine to where it runs very smooth. I fractured the muffler mount itself and had to reweld it.
   / Just bought a F3060! #62
The adjustment screw for the base idle is the vertical one below the throttle cam. The horizontal adjustment screw parallel to the throttle linkage sets the maximum RPM at full throttle. It usually has a small lead disc with safety wire on it.
Thanks for that tip. I will make adjustments before I mow again.
Doug
   / Just bought a F3060! #63
I am needing some help finding a replacement spline shaft for my f3060. The universal joint has fractured and i need to replace the shaft. picture showing the failed join and the triangular plate bolted to the motor below. I am wondering if they still make this shaft with the bolt on plate? or are they different because I cant find anything looking like this on line. It is the shaft connecting the motor and the HST
Here is the shaft and plate removed showing the fractured joint . Any thoughts?
here is the triangular plate mounted to the engine
Here is the plate removed.
   / Just bought a F3060! #65
Sorry, not able to see in the photos which piece has fractured?
   / Just bought a F3060! #66
You can buy complete new drive shaft for about $750 from any Kubota dealer, or buy individual parts as needed.
Below is a dealer I have ordered from many times.
Select Category: "Transmission" + Diagram "D10502 Universal Joint/Fan"
Messicks
   / Just bought a F3060! #67
Colemans in Kansas City has them and their shipping is actually sane as well. In fact my local Kubota dealer has them in stock. just checked yesterday. Complete and parts. Curious as to how you broke the driveshaft? Maybe I should say, from the looks of the first picture, an acute lack of grease is at fault.
2017 ISUZU NPRHD 16' BOX TRUCK (A60430)
2017 ISUZU NPRHD...
207280 (A52708)
207280 (A52708)
2019 KUBOTA U35-4 EXCAVATOR (A60429)
2019 KUBOTA U35-4...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2340 (A60432)
2340 (A60432)
2012 International Prostar (A61306)
2012 International...
