3-Point Hitch John Deere tlb 110
/ John Deere tlb 110 #1
richieg1
Valley stream NY
John Deere TLB 110
Very disappointed in John Deere I own a 2011 tlb 110 and can not find a three point hitch setup John Deere discontinued it and nobody there or the dealers can offer any solution. If anybody has any info were to get one that will work I would appreciate it.
Thanks
/ John Deere tlb 110 #2
For the most part the 4000 series hitches are interchangeable with the 110tlb. When building up a 3 ph from scratch I would suggest you buy the telescopic lower link arms. That makes hooking up to a clevis hitch implement much easier. If you have the aux hydraulics with the three rear remotes I would definitely recommend you go with a top and tilt hitch to start with.
I would have to look next time I take the backhoe off but as I recall the only difference may be the connection of the sway bar stabilizers and that is simple to fix. I ordered an extra pair of telescopic link arms with my 4520 purchase years ago and put them on the 110. Prior to that it was a pita to hookup my box blade, everything else I have is IMatch compatible which is the way to go.
There are solutions available so don't feel this is hopeless.
/ John Deere tlb 110 #5
/ John Deere tlb 110 #6
4700 & 4710 should have the same arms, as above the stab links will need a modification
/ John Deere tlb 110 #7
Thank you for reply never expected JD to be unresponsive if anybody out there owns a three point hitch all I need are the measurements of the draft bars and the top link so I no what I am looking for. You mention that the 4000 series tractors are the same just need sizes to match up
Thanks
Richie G
The pin holes are 29.5" on centers, thought the tape would be easier to read. One is a 4xxx telescopic link and one is a standard for the 110.
/ John Deere tlb 110 #8
Thanks for pictures are those bars still available if so do you have a part number
Thanks
/ John Deere tlb 110 #9
They are available for a high price imo. I just looked them up and a set of telescopic draft links through the parts department are $1,082. and the standard draft links are $709.
When I ordered my 4520 in 2009 I ordered two sets of the telescopic draft links, one for the 110 and one for the 4520. At that time the cost was about $330 per set. That leaves me with a set of the standard draft links for each tractor. I guess I need to lock them up.
All of the parts are available on the Deere parts site with drawings.
/ John Deere tlb 110 #10
Thanks
View attachment 463913View attachment 463912View attachment 463914View attachment 463915
http://www.tractorbynet.com/forums/...new-4300-project-post4423274.html#post4423274
I built one for my 4300 out of 2.5"x3/4" bar stock and some weld on ends from agrisupply. I drilled the holes where they needed to be, bent the link in the middle so it matched the stock arm, and welded the ends onto it. I had MAYBE an hour into making it and about $20 in parts/material. Now that it's painted it looks factory and it's been working fine every since. I also welded on extra hitch pin holders compared to OEM so I am never searching.
/ John Deere tlb 110 #11
Good job that saved some money.:thumbsup:
/ John Deere tlb 110 #12
I bought everything last year for my 110 tlb from my local Green Dealer my local yellow dealer gave me the same line. Yet the Green dealer pulled the 110 tlb. up on line JD factory parts I purchased everything new and had no problems. I would check if I were you. I am in PA but had good luck with Cazenovia Tractor who is a JD Green dealer in UpState Ny.
/ John Deere tlb 110 #13
Hey thanks for the ideas has anybody used neat attachments I just found them after my exhausting internet search they have a three point hitch setup part number 30383 it looks pretty good for $209.00 me being a newbie l am asking you guys for your experienced opinion if these will work. The extent of my hitch use will be a box blade, brush hog ,disk or tines for food plots
Thanks
Richie
/ John Deere tlb 110 #16
Then a mystery.. do you have a link?
/ John Deere tlb 110 #19
/ John Deere tlb 110 #20
Hey Doc i just came across a post of yours were you showed the whole 110 three point hitch including the instruction pamphlet if it is possible can you post that here because JD is a waste of time i can't get squat out of them. I am still on the hunt for the hitch sorry i missed your post on the lower lift arms i just look into the 4105 that hitch looks the same i just never new the measurements of anything so i didn't act on it now i know thanks to your post
thanks
richie g
429835 (A61166)
429835 (A61166)
Vermeer 604 XL-Series (A62177)
Vermeer 604...
2018 CATERPILLAR 232D SKID STEER (A64279)
2018 CATERPILLAR...
2012 Caterpillar 302.5C Mini Excavator (A61572)
2012 Caterpillar...
Pair of Assist Wheels (A64119)
Pair of Assist...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
