rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,753
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
What type of drive coupling or connection is between the front and rear pump. Just curious if that could have failed so the rear pump is not turning.
I agree with both of those ideas. Especially since you loosened the fitting on the steering pump ouput and got no flow out at all. Might as well hold off on the gauges until we find out if that steering pump is even turning.Exactly. What I would do next is simply remove the steering pump completely for further examination. Either the pump is completely toast or something's broken and the pump isn't even turning.
From what we know now, it may not be.
If the coupling is, the pump is turning, and the rotors look OK, then does that put us back to the suction & manifold? Or is there some other thing we are overlooking?
Did you replace that molded rubber piece that sits above the pumps? The one with the dog-leg bend?
