John Deere Full Throttle
/ John Deere Full Throttle #1
jhunter124
Northern California
2007 John Deere 3320
Hello all. Here is my problem. I have a 2007 John Deere 3320 that has ran fine since I bought it used a while back. The other day when starting it after it had sat for a week or so it went to full throttle. The key did not stop it and it ended up shutting down on its own about 20 seconds later. After getting my heart rate below 200, I was able to restart and operate it for the day with no problems. It did the same thing again and I had to stall it to shut it down. After doing that a few times it runs and starts fine every time afterwards. The dealer had me add fuel conditioner to it but I only have a few gallons of that ran through. I checked the fuel bowl and found no water in it and I will change the filter when I get home. Does anyone have any other ideas on what to do? Is there a cover that I can take off to access the injector rack/govenor to clean it? Should I just take it to the dealer for service? Thanks for your help.
/ John Deere Full Throttle #2
i would think something in the rack is sticking..
i'd for sure get it looked at before it becomes a runaway/ diesel bomb from winding up..
soundguy
/ John Deere Full Throttle #3
In case you haven't already, maybe find the fuel cutoff valve. On my unit, it is right on the fuel filter. O for open, C for closed.
If it still races with the valve closed, your may have a blown head gasket and be burning your oil.
/ John Deere Full Throttle #4
flashbacks from a 353 detroit goin on here!
/ John Deere Full Throttle #6
First welcome to TBN. Second i will be very interested to hear what you find out.
/ John Deere Full Throttle #7
You may have an oil leak somewhere that is putting oil into the intake.
Ralph
/ John Deere Full Throttle #8
you thinking turbocharger?
/ John Deere Full Throttle #9
I'm thinking it's an electronic glitch somewhere. I say that because the problem as described is intermittent. Unless I'm mistaken, you have a non-turbo direct injected Yanmar engine. Diesels that truly 'ran away' were usually the old 2-cycle detroits that scavenged the crankcase gasses.
/ John Deere Full Throttle #10
oil from a turbo seal might do it though..IF he has a turbo.. otherwise.. perhaps something in the head.. would have to be a good leak though.. that or his fuel shutoof is not working..
soundguy
/ John Deere Full Throttle #11
That's why I love the older tractors with the mechanical fuel shutoffs.
Does that tractor have load match, or whatever JD calls it - something that electronically senses the transmission load and changes the engine speed? My guess is something along those lines is calling for full rack on startup.
/ John Deere Full Throttle #12
load match does the opposite....it senses engine load and changes the tranny speed, thats why its only on e-hydro machines.....
Talked to serviceman at john deere who said most likely something in the governor is sticking. He recommended fuel conditioner, which I tried and it seemed to work until yesterday when it did it again. It is a non turbo yanmar with a power reverser transmission so luckily I can stall it when it winds up. After it does it a few times it starts and runs like normal for the rest of the day. I don't think it is a head gasket because oil and coolant are not mixing and levels of both are constant. The only electrical to the fuel circuit is the fuel shut off solenoid which is clicking when the ignition is turned off and on. The serviceman guessed in the thousands for repairs, ow, so I am thinking about trying to fix/clean it my self. Any ideas? Can I even find a service manual for an 07? Thanks for all of the input.
/ John Deere Full Throttle #14
i can't really imagine it being anything other than in the injector pump.. and liekly fuel rack.. also don't know what it would be more than at most about 1500$ if you replaced the whole darned thing unless that one is real spendy. I bet a diesel shop could service it for half that..
soundguy
/ John Deere Full Throttle #15
Does this only occur when starting up cold?
The computer on these tractors takes command on cold startups (somewhere around freezing) and runs at about half throttle for several seconds (I haven't timed it but probably 10 to 20 seconds). I suspect this would be even longer and possibly at higher rpm at lower temps. My only experience is in the 20's F.
This was quite a shock the first time it happened with my 3520 and I thought it was running much faster until I looked at the tack. Dealer said this is "normal" and even pointed out a somewhat general statement in the Owner's Manual that idle speed will be elevated for a period after cold startup. I haven't tried to turn the key off during this period, so I am not sure about that part.
/ John Deere Full Throttle #17
I know 'darn' little about this but am posting just to 'ferret-out' any additional info! I had been told that if a Diesel started pushing oil up through the rings, that it would burn the engine oil, as fuel, and 'take-off'! Other than stalling, with gears and brakes, it was 'out of control'! Forget the ignition switch. (Sorry if I said the same things from previous posters, in different words)...............~S
/ John Deere Full Throttle #18
A 'run-away' won't shut down with the key.
if it's a run away due to a stuck rack and you have a key-fuel off solenoid.. hmm.. I think it might...
soundguy
/ John Deere Full Throttle #19
soundguy
Hmmm, Technically, that's not a run-a-way.
A mole hill don't make a mountain.
/ John Deere Full Throttle #20
Kioti had a run of F.I. problems, mine sounded exactly like this one.
2007 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A60430)
2007 CHEVROLET...
TEST YOUR BID BUTTON! (A60430)
TEST YOUR BID...
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
2016 Toro Groundsmaster 4500-D 4WD Commercial Rotary Mower (A59228)
2016 Toro...
2022 FREIGHTLINER M2 26FT BOX TRUCK (A59905)
2022 FREIGHTLINER...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
