Mowing John Deere B with flail mower?
/ John Deere B with flail mower? #1
deereman10
Elroy, WI
John Deere 2440
Would it be possible to use a flail mower or whirlibird mower whatever with a john deere B?
/ John Deere B with flail mower? #2
If it has a pto shaft on the tractor centerline and a 3-point hitch, sure. You may need to add a few hundred pounds of weight to the front end to balance the weight of the mower.
/ John Deere B with flail mower? #3
You're pretty lean on hp with a B. Anything can be done, it's the results you may not be happy with.
/ John Deere B with flail mower? #4
Which "B"? Early models would probably struggle with a 4' mower. Late models should handle a 5' mower.
Does it have a PTO? (Required to power the mower).
Does it have a 3-point hitch? If not, you could still use a pull-type rotary cutter.
2013 Ford F-150 Ext. Cab Pickup Truck (A61573)
2013 Ford F-150...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
Landhonor Quick Attach Seeder (A66285)
Landhonor Quick...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
Kubota Z232 (A60462)
EZ Trail 3400 (A63688)
