Mowing John Deere B with flail mower?
/ John Deere B with flail mower? #1
deereman10
Elroy, WI
John Deere 2440
Would it be possible to use a flail mower or whirlibird mower whatever with a john deere B?
/ John Deere B with flail mower? #2
If it has a pto shaft on the tractor centerline and a 3-point hitch, sure. You may need to add a few hundred pounds of weight to the front end to balance the weight of the mower.
/ John Deere B with flail mower? #3
You're pretty lean on hp with a B. Anything can be done, it's the results you may not be happy with.
/ John Deere B with flail mower? #4
Which "B"? Early models would probably struggle with a 4' mower. Late models should handle a 5' mower.
Does it have a PTO? (Required to power the mower).
Does it have a 3-point hitch? If not, you could still use a pull-type rotary cutter.
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
2013 Ford Escape SUV (A61574)
2013 Ford Escape...
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
2023 Kubota L6060HST Compact Utility Tractor (A63688)
2023 Kubota...
Unverferth Perfecta 12 (A64126)
Unverferth...
Kubota L4802 DT LA766 Backhoe (A63688)
Kubota L4802 DT...
