Mowing John Deere B with flail mower?
/ John Deere B with flail mower? #1
deereman10
Elroy, WI
John Deere 2440
Would it be possible to use a flail mower or whirlibird mower whatever with a john deere B?
/ John Deere B with flail mower? #2
If it has a pto shaft on the tractor centerline and a 3-point hitch, sure. You may need to add a few hundred pounds of weight to the front end to balance the weight of the mower.
/ John Deere B with flail mower? #3
You're pretty lean on hp with a B. Anything can be done, it's the results you may not be happy with.
/ John Deere B with flail mower? #4
Which "B"? Early models would probably struggle with a 4' mower. Late models should handle a 5' mower.
Does it have a PTO? (Required to power the mower).
Does it have a 3-point hitch? If not, you could still use a pull-type rotary cutter.
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
APPROX (50)UNUSED CORRUGATED METAL SHEETS (A64281)
APPROX (50)UNUSED...
2R PLANTER, 3PT (A64280)
2R PLANTER, 3PT...
UNUSED AGT MX-MRT14 STAND-ON SKID STEER (A64280)
UNUSED AGT...
60" EXCAVATOR RAKE (A64279)
60" EXCAVATOR RAKE...
