John Deere 60 width
/ John Deere 60 width #1
Sterff
Central PA
IH 574, IH 656, IH 756, JD B, Kubota L4330
Does anyone know how wide a John Deere 60 tractor is with the tires in the most inner position? It has a wide front end as well as a 45 loader. I think if I take the loader off I can slide the wheels in to get it to fit on the trailer. The trailer is 83" wide.
/ John Deere 60 width #2
I think the width on the 60's is about 68" to 86".
Ok that sounds good. I saw that the widest setting was 86" but, I couldn't find the narrow setting. It hasn't run in a few years so loading it will be fun.
/ John Deere 60 width #4
What do plan on doing with it. Any pictures to go along?
I don't have any photos of it yet but, Ill take some soon. The tractor is at our neighbors at our moutain property. It has been sitting in a shed for as long as I can remember. I bought it as well as a 3-bottom JD plow, a JD pull behind mower, and a JD 3pt blade for $2000. The tractor has a wide front, 3pt hitch, power steering, and a 45 loader. The motor isn't stuck but, all the tires are flat. I plan on bringing it home and getting it running. Then I would like to run it for a year or so to work out any kinks before painting and restoring it. Eventually Id like to fix up the mower and plow as well.
/ John Deere 60 width #6
Have fun and good luck. The 60's have a nice bark when put under load. Is the tractor the standard tread or the row crop wide front?
It's a row crop. Hopefully I can bring it home within the next 2 months.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Wilmar Wrangler 4500 Loader (A66285)
Wilmar Wrangler...
500 BBL FRAC TANK TRAILER (A65643)
500 BBL FRAC TANK...
New/Unused AGROTK YC-32G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
Rake Master CR-50SG-LD (A64126)
Rake Master...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
