John Deere 60 width
/ John Deere 60 width #1
Sterff
Gold Member
Central PA
IH 574, IH 656, IH 756, JD B, Kubota L4330
Does anyone know how wide a John Deere 60 tractor is with the tires in the most inner position? It has a wide front end as well as a 45 loader. I think if I take the loader off I can slide the wheels in to get it to fit on the trailer. The trailer is 83" wide.
/ John Deere 60 width #2
I think the width on the 60's is about 68" to 86".
Ok that sounds good. I saw that the widest setting was 86" but, I couldn't find the narrow setting. It hasn't run in a few years so loading it will be fun.
/ John Deere 60 width #4
What do plan on doing with it. Any pictures to go along?
I don't have any photos of it yet but, Ill take some soon. The tractor is at our neighbors at our moutain property. It has been sitting in a shed for as long as I can remember. I bought it as well as a 3-bottom JD plow, a JD pull behind mower, and a JD 3pt blade for $2000. The tractor has a wide front, 3pt hitch, power steering, and a 45 loader. The motor isn't stuck but, all the tires are flat. I plan on bringing it home and getting it running. Then I would like to run it for a year or so to work out any kinks before painting and restoring it. Eventually Id like to fix up the mower and plow as well.
/ John Deere 60 width #6
Have fun and good luck. The 60's have a nice bark when put under load. Is the tractor the standard tread or the row crop wide front?
It's a row crop. Hopefully I can bring it home within the next 2 months.
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
6' Bush Hog (A62613)
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
