John Deere 60 width
/ John Deere 60 width #1
Sterff
Gold Member
Central PA
IH 574, IH 656, IH 756, JD B, Kubota L4330
Does anyone know how wide a John Deere 60 tractor is with the tires in the most inner position? It has a wide front end as well as a 45 loader. I think if I take the loader off I can slide the wheels in to get it to fit on the trailer. The trailer is 83" wide.
/ John Deere 60 width #2
I think the width on the 60's is about 68" to 86".
Ok that sounds good. I saw that the widest setting was 86" but, I couldn't find the narrow setting. It hasn't run in a few years so loading it will be fun.
/ John Deere 60 width #4
What do plan on doing with it. Any pictures to go along?
I don't have any photos of it yet but, Ill take some soon. The tractor is at our neighbors at our moutain property. It has been sitting in a shed for as long as I can remember. I bought it as well as a 3-bottom JD plow, a JD pull behind mower, and a JD 3pt blade for $2000. The tractor has a wide front, 3pt hitch, power steering, and a 45 loader. The motor isn't stuck but, all the tires are flat. I plan on bringing it home and getting it running. Then I would like to run it for a year or so to work out any kinks before painting and restoring it. Eventually Id like to fix up the mower and plow as well.
/ John Deere 60 width #6
Have fun and good luck. The 60's have a nice bark when put under load. Is the tractor the standard tread or the row crop wide front?
It's a row crop. Hopefully I can bring it home within the next 2 months.
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
2004 International 8600 Tender Truck (A63688)
2004 International...
John Deere TX Gator (A60462)
John Deere TX...
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
3 Brake Drums (A62613)
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
