John Deere 5425 tractor
/ John Deere 5425 tractor #1
b sisler
Terra Alta WV.
John Deere 5425
I have a problem , when i turn key on to start tractor ,the dash instrument panel lights take afew seconds to come on and then when attempting to complete the starting process by further turning the key ,the starter will fail to engage and all the instrument lights will go out does anybody out there have a clue to what is causing this malfunction?
/ John Deere 5425 tractor #5
Re: John derre 5425 tractor
I suggest you post your question over in the John Deere forum. Along with some other information is this an open-station or cab tractor. What you found out from having the battery tested. Has anything occurred before this happened and any tests you have already done.
John Deere Owning/Operating - TractorByNet.com
/ John Deere 5425 tractor #7
Sounds like a bad battery connection... Remove, clean, spray protectant/battery sealant, tighten and give 'er a go!
AKfish
/ John Deere 5425 tractor #8
Or a dead battery.
/ John Deere 5425 tractor #9
Have the battery load tested. Bad battery or bad connection
/ John Deere 5425 tractor #10
Sounds like bad ground connection as stated above. Clean battery terminals are something people tend to over look when general up keep is being done. Good luck!
New/Unused Wolverine 44in Mini Grapple Bucket (A65583)
New/Unused...
2013 Ford Taurus AWD Sedan (A64557)
2013 Ford Taurus...
JOHN DEERE 5403 TRACTOR (A65643)
JOHN DEERE 5403...
Hay Rack Wagon (A66408)
Hay Rack Wagon...
2004 MCI D4500 Bus, VIN # 1M8PDMPA44P056241 (A65563)
2004 MCI D4500...
Skid Steer Rotary Mulcher (A65640)
Skid Steer Rotary...
