3-Point Hitch John Deere 5075M hitch problem
   / John Deere 5075M hitch problem #31
My dealer is looking into the issue. I think I finally got him convinced that I have the standard duty hitch, yet the heavy duty 63mm lift cylinders. His ordering system is not showing a HD hitch as being an ordering option any longer for the 5M. Seems strange indeed.
   / John Deere 5075M hitch problem #33
pclausen,
As I understood it, through the 2011 model year, the heavy duty hitch was an option on the 5Ms, but for 2012 it became standard equipment. Once it became standard equipment, there would be no reason to have it as an option to order. It was one of the very few options that I didn't order, but after seeing this thread I regret that omission. I have a very heavy duty hydraulically offsetting flail mower which, no doubt, will put some serious stress on those hitch arms.
I wish you luck getting things figured out with your dealer. All of us 5M owners paid quite a bit to buy the most expensive utility tractor that JD makes in the 5Ms size, I'd like to believe that we were getting some real quality R&D and overall build in return.
Island Farmer
   / John Deere 5075M hitch problem #34
My understanding from this discussion is that Deere will NOT sell a customer the HD draft arms with the HD extendable link ends.
They will ONLY sell you the entire upgrade kit. Larger hydraulic lift cylinders, HD rockshaft lift arms and the HD draft arms, link ends, etc.
That's just goofy...
What's the problem with pairing a set of HD replacement draft arms with the HD extendable links and the smaller hydraulic lift cylinders and rockshaft arms? I don't recognize a product liability concern...
The draft links are gonna cause the hyd cylinders to fail; or break the rockshaft arms??? :rolleyes:
With the MY2012 tractor's and the changeover to HD only - definitely gives one the strongest impression that Deere was aware of a shortcoming with link ends.
AKfish
   / John Deere 5075M hitch problem #35
Stumbled upon this today while surfing the net for more information. At least I know Im not crazy....it exists.
Heavy-duty hitch
I found that as well yesterday and sent it to my dealer.
I basically asked him to explain what the difference was between LVB25778 (what is shown in the link above), and option code 8458 (the 63mm cylinders).
Btw, the link to the LVB25778 kit describes the cylinders as being 53mm. Not sure if that is a typo or if option code 8458 includes even larger lift cylinders. I did see the number "63" stamped on one of my cylinders. I'll measure the diameter with a caliber just to make sure what I have.
   / John Deere 5075M hitch problem #36
Agreed. But selling the larger lift cylinders with the standard duty extendable links and rockshaft arms is asking for trouble. And I think that is what I ended up with.
Only from what I'm seeing on my tractor, it would appear that they re-badged the SD hitch as HD and eliminated the HD altogether. That seems completely backwards! Maybe they had a few SD hitches left in the parts bin and decided to use them up before switching over to the HD only hitches? :mad:
   / John Deere 5075M hitch problem #37
Most definitely!!! That's a serious problem - waiting for a place to happen! :eek:
That's a "64 dollar question"... After you measure the hyd lift cylinders, you might also check the part number for the rockshaft lift arms.
You might have 2/3 of the HD system - cylinders and rockshaft arms - minus the HD draft arms and extendable links.
AKfish
Ok all, heres an update. I spoke with Jake Brown, a JD regional rep who is covering for our regional rep since there was a death in her family. I explained my situation to Jake, including all contact I have had with Deere, my dealer, etc. He was very receptive to my concerns, and I explained how I felt the hitch design was flawed, and certainly not up to the quality standard that the premium 5M series utility tractors should exude. His reply to that was that Deere trys to find middle ground when building tractors so that they can meet demands of different buyers. My rebutle to that was, if a serious tractor operator was looking to buy a tractor he or she could USE, they would go with the 5M line, expecting heavy duty. Standard duty on the top of the line tractor doesnt cut it. If I wanted to cheap`n up the tractor, allow me to spec in a lighter hitch, but standard equipment should be heavy enough to meet the demands. If I wanted a lighter, and cheaper tractor, I would have went with an E series. (Not that they are bad, but they arent on the same level as the M)
In terms of selling me ONLY the lower HD arms, he said "those parts are available through certain channels, but he would not make them available to me because he didnt want the HD arms coupled with standard duty upper components and cylinders for fear of future trouble)
After about 45 minutes of polite and fair talk, he asked what we wanted in order to "make things right". My response was: To allow us to purchase the entire HD hitch upgrade kit at the original price that would have been charged if we would have spec`d the tractor from new. He said that sounded fair and would research the price and get back to me. He called me back after about ten minutes, and explained that the price his books show for the original spec cost on that kit was approx. $1,500. (Basically the same price as what they retail for now through JD Parts, which makes very little sense to me). After seeing that price, Jake said my "dealer was already working pretty well with me, having offered me the kit for their cost $1,100, having a $400 savings." I explained I felt that price was still out of line, and that I shouldnt have to fork out another $1,100 for a problem that I neither wanted nor created on a tractor with under 20hrs operating time, and now going on 3 weeks of down-time. Jake said he "doesnt want us walking away unhappy over this, so we could (im assuming here) make a reasonable counter offer on the kit, and he would take it in to consideration and see what he could do, but there "werent a whole lot of options at this point"
So I have to make a decision and get back to him this week. After discussing it with the other guy I farm with, we feel the offer is NOT reasonable, and Deere needs to do better by us.
This is where you guys come in. What do you think? What would you do? Should we all get together and push the issue?, as it seems I`m not the only one who is dissatisfied with the hitch.
Im curious to hear your thoughts and input...needless to say I am far from satisified how things went today. I kinda feel like Im getting the big Green and Yellow shaft at this point. AK I agree completely with what you said, the more I go through this, the more I feel Deere is WELL AWARE of the shortfall in this standard duty hitch design, but doesnt want to own up to it.
Im currently browsing the JD parts program. If you search for a 5115M (which is the new top-of-the-range 5M, under the hitch section it lists "Draft Link, Standard, Telescopic" and shows a picture of exactly that; the standard duty draft links....the exact same ones that are currently on my tractor down to the same individual part numbers.
At least in the MY 2011 and previous, if you bought a 5105M (now 5115M) you got the HD draft links (with lift-type telescopic locks) as STANDARD equipment. Apparently, the MY2012 range doesnt offer the HD set as standard. Its shown as an attachment or option. See attached picture.
Like someone else previously said, they scratched off the "Standard Duty" markings, and over-stamped them with "Heavy Duty".....wait you see isnt exactly what you get.
I checked the next tractor down MY2012 5100M and under the hitch section, the HD kit appears as listed....the pictures match the HD kit I am currently requesting from Deere...right down to the pull-up type telescopic locking system.....
This just gets more weird by the minute.....
   / John Deere 5075M hitch problem #40
I don't think the JD rep found the correct option prce for the HD upgrade. Why would the factory charge the same as "parts" when they did not have to supply all the std parts you would have if you bought from parts? Everyone knows the price of the parts is much greater than the price of the whole. I think Henry Ford said "We could give them the car, if they bought all the parts only from us" Or something similar.
I would tell the JD rep, Yes, my JD dealer is willing to work with me to the tune of $400. Now John Deere Corporate should be willing to work with me too, to the tune of, say $600. I'll pay $500 and you can have the replaced parts from a 20 hour tractor just as if it had come with the HD parts it should have.
I would think JD would be happy to settle this for $600 (on paper), bet their "real" cost is less.
Club Car Utility Cart (A55853)
Club Car Utility...
PAZA 3PT SPIN SPREADER (A52708)
PAZA 3PT SPIN...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2016 Make...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
STREET STRIDER ETX EXERCISE BOKE (A58374)
STREET STRIDER ETX...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52708)
KNOW BEFORE YOU...
