John Deere 5045
/ John Deere 5045 #1
DCuz
Thornton, Texas
John Deere 5045
I was shredding brush when it stopped running. Like you turned key off. I have lights and gauges work. Starter will not turn over. I'm sure a wire got pulled loose but don't see any scanning over it. Any ideas where to start? Thanks.
/ John Deere 5045 #2
Start with the simple things. Are all the fuses good? Here is a link to an online operators that will have fuse info. Have you checked the safety switch wiring. I am sure you have done this, but cannot hurt to mention it, did you turn the PTO off.
John Deere Ag - New Equipment: Technical Publications - Equipment Search
I have attached a few starting system. I do not know how close it will match your tractor, but can not hurt to take a look at it.
  • 5103starting_system.pdf
  • 5105starting_system.pdf
/ John Deere 5045
Thank your. Fuses will be my next step.
/ John Deere 5045 #4
Have you disengaged the PTO before reattempting to start it?
Engine knock
Engine knock
2018 Rotary SM18N001 18,000lb. Hydraulic 4-Post Auto Lift (A66736)
2018 Rotary...
2014 LEVIATHAN  T-BELT TRAILER (A67714)
2014 LEVIATHAN...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
55 GALLON CONTAINERS OF FLUIDS QTY OF 6 (A67714)
55 GALLON...
Vortex Walk-Behind Paint Sprayer (A64553)
Vortex Walk-Behind...
