John Deere 5045
/ John Deere 5045 #1
DCuz
Thornton, Texas
John Deere 5045
I was shredding brush when it stopped running. Like you turned key off. I have lights and gauges work. Starter will not turn over. I'm sure a wire got pulled loose but don't see any scanning over it. Any ideas where to start? Thanks.
/ John Deere 5045 #2
Start with the simple things. Are all the fuses good? Here is a link to an online operators that will have fuse info. Have you checked the safety switch wiring. I am sure you have done this, but cannot hurt to mention it, did you turn the PTO off.
John Deere Ag - New Equipment: Technical Publications - Equipment Search
I have attached a few starting system. I do not know how close it will match your tractor, but can not hurt to take a look at it.
  • 5103starting_system.pdf
  • 5105starting_system.pdf
/ John Deere 5045
Thank your. Fuses will be my next step.
/ John Deere 5045 #4
Have you disengaged the PTO before reattempting to start it?
1987 FORD F-350 CUSTOM SERVICE TRUCK (A64280)
1987 FORD F-350...
LOOK! (A65640)
LOOK! (A65640)
2023 Tesla Model 3 Sedan (A66738)
2023 Tesla Model 3...
2009 ALLMAND MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
MANIFOLD (A68842)
MANIFOLD (A68842)
