john deere 4500
/ john deere 4500 #1
garcin
manchester maryland
john deere 4500
after loaning tractor out it came back with steering jerky and loader wont raise need help
/ john deere 4500 #2
sounds like a relief valve poped some were check the presser from the lines and your oil level good luck ...ps you got to love lending your stuff
/ john deere 4500 #3
The 4500 has a "common" oil sump but uses two pumps: one for steering, one for the other hydraulics. With problems in both systems, I would suspect a problem in the suction line: a clogged strainer or possibly a collapsed line. That line runs from the pumps (near the front of the engine) down to the strainer (in lower front of the transmission sump).
/ john deere 4500 #4
Yes, that is what I would expect, too. There is a good chance the user hit the main oil
suction line underneath the tractor and punctured or pinched it.
Around here, I MIGHT lend out any of my tools if it does not have:
> a cutting edge
> any moving parts
/ john deere 4500 #6
> a cutting edge
> any moving parts[/QUOTE]
I think I will adopt that line of thought. Although I am pretty picky of who leaves the yard with what. The sad part is they expect to use everything for nothing. They must think I pick diesel fuel off the apple tree.
/ john deere 4500 #7
Had a "friend" barrow a chainsaw. He ran out of gas mix so he finished up with pure gas. That was when I learned not to loan out things and how to rebuild a chainsaw engine.
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
1979 AM General 6X6 Truck (A65563)
1979 AM General...
2016 CATERPILLAR CP44B PADFOOT ROLLER (A65053)
2016 CATERPILLAR...
Rogator RG1300C (A63689)
Rogator RG1300C...
