John Deere 4200 HST transmission problem
/ John Deere 4200 HST transmission problem #1
butchchris
honeoye falls
jd 4200 hst
Driving Tractor in Low Gear and transmission jumped out of Gear
Tractor is in Neutral and will not go in any Gear
Any Ideas to Try / Fix?
/ John Deere 4200 HST transmission problem #2
I believe some folks have had problems with shaft going into the housing breaking off??:)
Egon
PTO runs fine
but tractor does not move when you depress pedal
/ John Deere 4200 HST transmission problem #4
Egon was talking about the shaft going to the range selector. There is a o-ring groove in the shaft and 4x00 are known to break off. If you do a search there will be hours of fun reading.
I would shut off the tractor and try to engage the range selector.
/ John Deere 4200 HST transmission problem #5
Thank you. That is what I was visualizing but not stating properly.:eek:
Looking @ parts diagram I see this shaft but it has a spring pin (which I'm thinking is what has failed) that attaches it to drive bushing
PTO shaft runs okay, so I am assuming this is where the break in power line is.
Do you know if this is an easy fix?
Is there an cover which I can remove to change out spring pin?
or do I need to disassembly entire transmission?
/ John Deere 4200 HST transmission problem #7
Why do you assume it is a spring pin? If the shift shaft has
broken off entirely, it would have separated. If not, then it
could be one of 2 pins, yes.
There is one holding the shaft to the external bellcrank, and one inside
the trans, holding the shaft to the shifter fork.
Fully replacing the shaft does not require taking apart the trans, but
you would have to remove the 3-pt cylinder housing. I have done 2 of
these repairs.
Found problem
Broken shifting fork
John Deere most have know it was problem
They can out with a new robust kit to replace both shifting forks, housing and shaft
I fell a lot better about this repair now
Much stronger design!
/ John Deere 4200 HST transmission problem #10
Found problem
My shifting fork for a&b range broke. i was wondering how you got the new forks back into place?
/ John Deere 4200 HST transmission problem #11
Tractor is in Neutral and will not go in any Gear Nox Vidmate VLC
2012 PROCO KILL TRAILER (A67714)
2012 PROCO KILL...
LEEBOY  1000 PAVER (A67714)
LEEBOY 1000 PAVER...
New - Front mount rototiller
New - Front mount...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2020 PETERBILT 367 (A67714)
2020 PETERBILT 367...
535 GAL WATER TANK (A68842)
535 GAL WATER TANK...
