john deere 2040
/ john deere 2040 #1
david shelton
louisa virginia
2040 john deere
got a 2040 john deere got a new veil hydraulic pump new filter cleaned cart., new fluid still can't fluid threw the lines just spurs out what could be the problem?
/ john deere 2040 #3
What's the serial number of your tractor as early models are open-center & later models are closed-center hyd's?
/ john deere 2040
255246L is serial and code is 204SA any help I would be grateful right now I'm lost. Thanks
/ john deere 2040 #5
It's possible the trans pump lost it's prime or one of it's gears broke.
/ john deere 2040
it's supposedly a new pump and I prime when I installed it the first time. I had a little water in fluid at first so I changed the fluid and filter, three times thinking that maybe the water was my problem now I don't have any moisture still no pressure.
/ john deere 2040 #7
Have you checked sump screen(parts key 30)?
/ john deere 2040 #8
Remove coverplate over shiftcover ...on the righthandside you will see 2 testplugs ......to test your oilpressure ......front 1 should be near/just over 10 bar .....rear 1 also about there .....rear 1 delivers oil to front pistonpump
/ john deere 2040
Thanks for correcting me
sorry it's taken so long to get back with y'all but anyway I removed the low pressure relief valve and I've got full function of hydraulics I know this puts me back to filter or transpump I've changed filter several times but still moisture in fluid any ideas thanks david
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
Landhonor TP2-13-08D Skid Steer Mount Tree Puller  (A62679)
Landhonor...
2018 Cat D6T LGP VPAT Dozer (A62679)
2018 Cat D6T LGP...
CrusterBuster 4000 Grain Drill (A63688)
CrusterBuster 4000...
Deere 333E (A60462)
Deere 333E (A60462)
2017 Caterpillar 308E2 (A64126)
2017 Caterpillar...
