john deere 2040
/ john deere 2040 #1
david shelton
louisa virginia
2040 john deere
got a 2040 john deere got a new veil hydraulic pump new filter cleaned cart., new fluid still can't fluid threw the lines just spurs out what could be the problem?
/ john deere 2040 #3
What's the serial number of your tractor as early models are open-center & later models are closed-center hyd's?
/ john deere 2040
255246L is serial and code is 204SA any help I would be grateful right now I'm lost. Thanks
/ john deere 2040 #5
It's possible the trans pump lost it's prime or one of it's gears broke.
/ john deere 2040
it's supposedly a new pump and I prime when I installed it the first time. I had a little water in fluid at first so I changed the fluid and filter, three times thinking that maybe the water was my problem now I don't have any moisture still no pressure.
/ john deere 2040 #7
Have you checked sump screen(parts key 30)?
/ john deere 2040 #8
Remove coverplate over shiftcover ...on the righthandside you will see 2 testplugs ......to test your oilpressure ......front 1 should be near/just over 10 bar .....rear 1 also about there .....rear 1 delivers oil to front pistonpump
/ john deere 2040
Thanks for correcting me
sorry it's taken so long to get back with y'all but anyway I removed the low pressure relief valve and I've got full function of hydraulics I know this puts me back to filter or transpump I've changed filter several times but still moisture in fluid any ideas thanks david
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
Mahindra Emax 22S Loader Tractor (A66285)
Mahindra Emax 22S...
Covington TP-66 Planter (A64127)
Covington TP-66...
2022 EZ-GO ELITE...
Front Tank Bracket (A64126)
Front Tank Bracket...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
