john deere 2040
/ john deere 2040 #1
david shelton
louisa virginia
2040 john deere
got a 2040 john deere got a new veil hydraulic pump new filter cleaned cart., new fluid still can't fluid threw the lines just spurs out what could be the problem?
/ john deere 2040 #3
What's the serial number of your tractor as early models are open-center & later models are closed-center hyd's?
/ john deere 2040
255246L is serial and code is 204SA any help I would be grateful right now I'm lost. Thanks
/ john deere 2040 #5
It's possible the trans pump lost it's prime or one of it's gears broke.
/ john deere 2040
it's supposedly a new pump and I prime when I installed it the first time. I had a little water in fluid at first so I changed the fluid and filter, three times thinking that maybe the water was my problem now I don't have any moisture still no pressure.
/ john deere 2040 #7
Have you checked sump screen(parts key 30)?
/ john deere 2040 #8
Remove coverplate over shiftcover ...on the righthandside you will see 2 testplugs ......to test your oilpressure ......front 1 should be near/just over 10 bar .....rear 1 also about there .....rear 1 delivers oil to front pistonpump
/ john deere 2040
Thanks for correcting me
sorry it's taken so long to get back with y'all but anyway I removed the low pressure relief valve and I've got full function of hydraulics I know this puts me back to filter or transpump I've changed filter several times but still moisture in fluid any ideas thanks david
2001 Sun Coast Trailers T/A 20ft Enclosed Trailer (A61569)
2001 Sun Coast...
2006 Volvo VNM Day Cab Truck Tractor (A61568)
2006 Volvo VNM Day...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2004 AMMANN AV33E Smooth Drum Roller (A61166)
2004 AMMANN AV33E...
New/Unused Landhonor Quick Attach Pallet Forks (A61166)
New/Unused...
2023 Chevrolet Express 2500 Cargo Van (A61568)
2023 Chevrolet...
