john deere 2040
/ john deere 2040 #1
david shelton
louisa virginia
2040 john deere
got a 2040 john deere got a new veil hydraulic pump new filter cleaned cart., new fluid still can't fluid threw the lines just spurs out what could be the problem?
/ john deere 2040 #3
What's the serial number of your tractor as early models are open-center & later models are closed-center hyd's?
/ john deere 2040
255246L is serial and code is 204SA any help I would be grateful right now I'm lost. Thanks
/ john deere 2040 #5
It's possible the trans pump lost it's prime or one of it's gears broke.
/ john deere 2040
it's supposedly a new pump and I prime when I installed it the first time. I had a little water in fluid at first so I changed the fluid and filter, three times thinking that maybe the water was my problem now I don't have any moisture still no pressure.
/ john deere 2040 #7
Have you checked sump screen(parts key 30)?
/ john deere 2040 #8
Remove coverplate over shiftcover ...on the righthandside you will see 2 testplugs ......to test your oilpressure ......front 1 should be near/just over 10 bar .....rear 1 also about there .....rear 1 delivers oil to front pistonpump
/ john deere 2040
Thanks for correcting me
sorry it's taken so long to get back with y'all but anyway I removed the low pressure relief valve and I've got full function of hydraulics I know this puts me back to filter or transpump I've changed filter several times but still moisture in fluid any ideas thanks david
Case 90XT Skidsteer Loader (A66285)
Case 90XT...
We do NOT accept credit cards as payment. (A64127)
We do NOT accept...
2021 Caterpillar 303.5E2 (A64126)
2021 Caterpillar...
2015 Ford Explorer AWD SUV (A61569)
2015 Ford Explorer...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2011 PETERBILT 367 (INOPERABLE) (A65643)
2011 PETERBILT 367...
